uniFi plugin setup help!
Sun May 24, 2020 8:36 pm
Re: uniFi plugin setup help!
The config parameter for the web page login is wrong
Not api/s but the one with login
Sun May 24, 2020 10:39 pm
hamw offline
I think you are telling me to add something to the ...http Api Login page, which is circled below. Should I put:
api/s/login,
api/s/username:password
Or something else? I have tried a bunch of stuff and keep getting errors.
 uniFiAP Error                   UNIFI executeCMDOnController  login cmd:/usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "UserName", "strict": true, "password": "PassWord"}' 'https://10.0.1.1:8443/api/s/login'
gives  error: {"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}
   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100   126  100    63  100    63   1517   1517 --:--:-- --:--:-- --:--:--  1536
Also, I added in my AP, which seem to work fine. Devices populate and appear to keep track of the up/down status. However, I added switches.... both the APs and the switches use the same username and password... but getting authentication errors for the switches.
uniFiAP Error                   getMessages: (1 - test connect)  error for SWdict, ip#: 10.0.1.83 wrong ip/ password or system down or ssh timed out or ..?
   uniFiAP Error                   testServerIf ssh connection to server failed, cmd: /usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/test.exp' 'UserName' 'PassWord' 10.0.1.84
   uniFiAP Error                   getMessages: (1 - test connect)  error for SWdict, ip#: 10.0.1.84 wrong ip/ password or system down or ssh timed out or ..?
   uniFiAP Error                   getMessages: (1 - test connect)  error for APtail, ip#: 10.0.1.95 wrong ip/ password or system down or ssh timed out or ..?
UDM api s login.jpeg (145.22 KiB) Viewed 1395 times
Mon May 25, 2020 6:09 am
/api/login as shown in the line below
either
/api/login for UDM and std
or
/api/auth/login for UDMpro
Use the latest version, select the controller type you have, then click on set parameters
that should fill the fields with the proper values
Mon May 25, 2020 8:02 am
hamw offline
I set login as noted in the pic.
Based on this.... api.err.Ubic2faTokenRequired"},"data":[]} I turned off 2FA and that seems to have done the trick. Thanks!
   uniFiAP Error                   UNIFI executeCMDOnController  login cmd:/usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "USERNAME", "strict": false, "password": "PASSWORD"}' 'https://10.0.1.1:8443/api/login'
gives  error: {"meta":{"rc":"error","msg":"api.err.Ubic2faTokenRequired"},"data":[]}
100   134  100    70  100    64     68     62  0:00:01  0:00:01 --:--:--    68
One other problem is that my switches seem to be kicking me out for SSH. Any ideas on that? Results in an error.
Mon May 25, 2020 8:18 am
could you be more specific:
"One other problem is that my switches seem to be kicking me out for SSH"
when and how? after you login or when trying to login and how to you test?
be explicit!
