- Code: Select all
plt.figure(figsize=(0.5,0.5))
What is the smallest circle which could be made?
Because 0.1,01 give a square.
mikkyo wrote:I figured I'd try this, haven't done any scripting within Indigo yet..
Indigo 7.4.1
macOS Catalina 10.15.4
Created a New Schedule
Under Action Execute Script (Scripts and File Actions)
Copied the script from the git hub repo, tried it in an embedded script, got Invalid Syntax
Saved it to a file battery-charting-script.py in the /Library/Application Support/PerceptiveAutomation/Scripts, and choose it as the file to run, got
Script Error battery-charting-script.py: invalid syntax
Script Error around line 349 - "print(s, file=self.fileo)"
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import sys
import matplotlib.pyplot as plt
import numpy as np
except ImportError, e:
sys.exit(u"The matplotlib and numpy modules are required to use this script.")
# =================== User Settings ===================
output_file = '/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/images/controls/static/battery_test.png' # Indigo 7 installs
chart_title = 'Battery Health'
x_axis_title = ''
y_axis_title = ''
background_color = '#000000'
chart_height = 4.5
chart_width = 6
font_color = '#FFFFFF'
font_name = 'Lato Light'
font_size = 9
grid_color = '#888888'
grid_style = 'dotted'
show_data_labels = True
title_font_size = 9
battery_full_color = '#0000CC'
battery_caution_color = '#FFFF00'
battery_low_color = '#FF0000'
battery_caution_level = 10
battery_low_level = 5
# =================== kwarg Settings ===================
k_bar_fig = {'align': 'center',
'alpha': 1.0,
'height': 0.5,
'zorder': 3
k_grid_fig = {'which': 'major',
'color': grid_color,
'linestyle': grid_style,
'zorder': 0
k_plot_fig = {'bbox_extra_artists': None,
'bbox_inches': 'tight',
'dpi': 100,
'edgecolor': background_color,
'facecolor': background_color,
'format': None,
'frameon': None,
'orientation': None,
'pad_inches': 0.1,
'papertype': None,
'transparent': True,
k_title_fig = {'fontname': font_name,
'fontsize': title_font_size,
'color': font_color,
'position': (0.35, 1.0)
bar_colors = []
device_dict = {}
x_values = []
y_values = []
# Create a dictionary of battery powered devices and their battery levels
for dev in indigo.devices.itervalues():
if dev.batteryLevel is not None:
device_dict[dev.name] = dev.states['batteryLevel']
if device_dict == {}:
device_dict['No Battery Devices'] = 0
except Exception, e:
indigo.server.log(u"Error reading battery devices: %s" % e)
# Parse the battery device dictionary for plotting.
for key, value in sorted(device_dict.iteritems(), reverse=True):
x_values.append(float(value))
except ValueError:
x_values.append(0)
y_values.append(key.replace(' - ', '\n')) # This line is specific to my install, as I name devices "Room - Device Name"
# Create a list of colors for the bars based on battery health
battery_level = float(value)
except ValueError:
battery_level = 0
if battery_level <= battery_low_level:
bar_colors.append(battery_low_color)
elif battery_low_level < battery_level <= battery_caution_level:
bar_colors.append(battery_caution_color)
bar_colors.append(battery_full_color)
indigo.server.log(u"Error parsing chart data: {0}".format(e))
# Create a range of values to plot on the Y axis, since we can't plot on device names.
y_axis = np.arange(len(y_values))
# Plot the figure
plt.figure(figsize=(chart_width, chart_height))
# Adding 1 to the y_axis pushes the bar to spot 1 instead of spot 0 -- getting it off the axis.
plt.barh((y_axis + 1), x_values, color=bar_colors, **k_bar_fig)
if show_data_labels:
for ii in range(len(y_axis)):
plt.annotate("%3d" % x_values[ii], xy=((x_values[ii] - 5), (y_axis[ii]) + 0.88), xycoords='data', textcoords='data', fontsize=font_size, color=font_color)
# Chart
plt.title(chart_title, **k_title_fig)
plt.grid(**k_grid_fig)
# X Axis
plt.xticks(fontsize=font_size, color=font_color)
plt.xlabel(x_axis_title, fontsize=font_size, color=font_color)
plt.gca().xaxis.grid(True)
plt.xlim(xmin=0, xmax=100)
# Y Axis
# The addition of 0.05 to the y_axis better centers the labels on the bars
# (for 2-line labels.) For 1 line labels, change 1.05 to 1.0.
plt.yticks((y_axis + 1.05), y_values, fontsize=font_size, color=font_color)
plt.ylabel(y_axis_title, fontsize=font_size, color=font_color)
plt.gca().yaxis.grid(False)
plt.ylim(ymin=0)
# Output the file
plt.savefig(output_file, **k_plot_fig)
plt.close()
DaveL17 wrote:I think something strange may be happening with the code that you pasted into the script window. I just copied the script from Github into a new embedded script window, changed the image file save path to Indigo 7.4 for my version, and selected run. The script ran without error and generated an image file to the target folder. Try copying this script instead:
ryanbuckner wrote:DaveL17 wrote:I think something strange may be happening with the code that you pasted into the script window. I just copied the script from Github into a new embedded script window, changed the image file save path to Indigo 7.4 for my version, and selected run. The script ran without error and generated an image file to the target folder. Try copying this script instead:
This worked for me right out of the box. I just updated for 2021.1 path
1 question, what if I wanted to sort the order by battery level low --> high ?
for key, value in sorted(device_dict.iteritems(), key = lambda x : x[1], reverse=True): # Edited this line to sort by battery level value
