Does anyone have at the fairly new Zooz ZEN25 (double plug module) that they're currently using under Indigo? I see that the ZEN15 and ZEN20 are supported and wondering if it'll work without having a new device definition. Thanks.
Ralph
matt (support) wrote:Hi Ralph,
I just checked and we do have a device info report submitted by someone that has one. It sounds like only 1 outlet is controllable from Indigo currently, so we'll look at adding a definition to get both outlets working correctly.
Z-Wave Syncing - started for "073 - Relay Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 2, 6, 9, 10, 16, 25, 37, 38, 39, 41, 47, 48, 50, 53, 58, 66, 70
Z-Wave Syncing - assigning return route to "073 - Relay Power Switch"
Z-Wave Syncing - retrieved manufacture and model names: Zooz - 027A, Relay Power Switch - A000A003
Z-Wave Syncing - retrieved protocol version 5.03, app version 2.00
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 25v1 86v1 27v1 6Cv1 72v1 8Ev1 70v1 71v1 32v4 73v1 55v1 59v1 5Av1 85v1 7Av1 5Ev1 9Fv1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E 25 32 6C 9F], 2:[5E 85 59 8E 25 32 6C 9F], 3:[5E 85 59 8E 25 32 6C 9F]
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - created device "073 - Relay Switch"
Z-Wave Syncing - created device "073 - Relay Switch 2"
Z-Wave Syncing - created device "073 - Relay Switch 3"
Z-Wave Syncing - complete
Indigo Z-Wave Version: 7.4.0
Node ID: 73
Model: Relay Power Switch
Model ID: A000A003
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 5.03
Application Version: 2.00
Model Definition Version: 0
Library Type: 3
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v4 25v1 86v1 27v1 6Cv1 72v1 8Ev1 70v1 71v1 32v4 73v1 55v1 59v1 5Av1 85v1 7Av1 5Ev1 9Fv1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01)
Multi-Endpoint Classes: 1:[5E 85 59 8E 25 32 6C 9F], 2:[5E 85 59 8E 25 32 6C 9F], 3:[5E 85 59 8E 25 32 6C 9F]
Features: routing, beaming, energyMeter
Neighbors: 2, 6, 9, 10, 16, 25, 37, 38, 39, 41, 47, 48, 50, 53, 58, 66, 70
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
roquej wrote:Is there a way to turn off the "energy reporting"?
JP
roquej wrote:It seems the "Periodic power reports" and "Periodic energy reports" parameters don't do anything. Tried setting to 0 (disable) and I get an error. See the picture enclosed.
What am I doing wrong?
JP
aldera wrote:roquej wrote:It seems the "Periodic power reports" and "Periodic energy reports" parameters don't do anything. Tried setting to 0 (disable) and I get an error. See the picture enclosed.
JP
Looks like the range limits of 30 to 2678400 for each parameter is overriding the ability to enter any number below 30, including the 0. I get the same results.
RS
