There’s a plug-in in for the Concord 4 in the plugin store. Requires the serial automation interface.
jalves wrote:Have played around a little with this Node-Red thing. Haven't gotten it do do anything special for me and honestly can't think of a use-case in my setup. But I do like to explore new things.
So, I just did a search and see there is a Node-Red device (is that the right word) for Alarm.com. This intrigues me. One of the things I've meant to do over the years is to integrate my Concord 4 alarm system into Indigo. Right now I control it entirely through my alarm company's internet interface (which appears to be alarm.com). If the node-red device would give me an easy way to include it into Indigo then I have a use-case.
Anybody invested Alarm.com interfacing with Node-Red?
siclark wrote:If you have Alexa working and don't mind everything being bulbs or don't use it, and all your devices are supported via plugins then no use.
If you want to make the Alexa integration tighter with proper Alexa devices as we have in homekit or want to use other devices that aren't supported in indigo yet then yes there is a use case. It's very quick and easy to get up and running and does integrate into indigo directly or via mqtt.
jay (support) wrote:siclark wrote:If you have Alexa working and don't mind everything being bulbs or don't use it, and all your devices are supported via plugins then no use.
I'm confused - was he asking about Alexa?
jalves wrote:I wasn't. I just want to get sensor (door, window, smoke) info and system condition (armed, disarmed) into Indigo.
