uniFiAP Error in Line 3909 has error=local variable 'ret' referenced before assignment Connection
uniFiAP Error error:>> <Response [401]> Reconnect
fixed in v .185, just posted
durosity wrote:evansgo wrote:OK some progress
So I decided to take a gamble and install the UDM Pro firmware as I had read that even through it said pro only it would work. Well it does, you have to fully reset to factory defaults the UDM, but I am now on controller version 5.12.59 and FW 1.6.4.2306.
I’m amazed that worked.. but also quite impressed! How does the devices page look when you’re looking at the port settings for the switch, etc?
evansgo wrote:Not sure its all a bit of a mess with the UDM's at the moment. There are about three different versions of FW out for it. But I saw that someone had tried the pro FW and partly got it to work. So I backed up, did a full factory reset, tried it, restored setup and its been flawless, who knew
uniFiAP Error getMessages: forcing restart of listener for: dictLoop.exp @ SWdict after 192.168.10.1 sec without message180
uniFiAP Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Error unable to execute action -- com.karlwachs.utilities not found or installed
uniFiAP Error getMessages: forcing restart of listener for: dictLoop.exp @ SWdict after 192.168.10.1 sec without message601
uniFiAP Warning getMessages: ListenProcess started for uType: SWdict; ip: 192.168.10.1 pid:7552
uniFiAP Error getMessages: forcing restart of listener for: dictLoop.exp @ APdict after 192.168.10.9 sec without message743
uniFiAP Warning getMessages: ListenProcess started for uType: APdict; ip: 192.168.10.9 pid:8164
16:56:43 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "xxx", "strict": true, "password": "xxx"}' 'https://x.x.x.x:8443/api/login'
16:56:43 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie --data '{"_limit": 45, "within": 999, "_sort": "+time"}' -X PUT 'https://x.x.x.x:8443/api/s/default/stat/event'
2020-04-27 16:56:43.618 ERROR Plugin.executeCMDOnController Connection error: >>192.168.10.1<<
{"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}
durosity wrote:I've not had this plugin setup for some time so excuse me if I've missed something obvious here. I've just updated to the new version released last night.. when I try to enable the 'UDM Active' box when saving the whole form goes red. If it's not selected it'll let me save. Any ideas?
