autolog wrote:Hi Joe,FlyingDiver wrote:... Try leaving that field blank and see what happens.
Looks like that worked
OK, I'm going to add a note to that effect in the dialog box.
siclark wrote:Wow those motion sensors are smaller than they look and are crazily cheap
zigbee2mqtt:info 2020-02-23 12:35:09: Device 'innr_flex_light_1' joined
zigbee2mqtt:info 2020-02-23 12:35:09: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"device_connected","message":{"friendly_name":"innr_flex_light_1"}}'
zigbee2mqtt:info 2020-02-23 12:35:09: Starting interview of 'innr_flex_light_1'
zigbee2mqtt:info 2020-02-23 12:35:09: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"interview_started","meta":{"friendly_name":"innr_flex_light_1"}}'
zigbee2mqtt:info 2020-02-23 12:35:20: Successfully interviewed 'innr_flex_light_1', device has successfully been paired
zigbee2mqtt:info 2020-02-23 12:35:20: Device 'innr_flex_light_1' is supported, identified as: Innr Color Flex LED strip (FL 130 C)
zigbee2mqtt:info 2020-02-23 12:35:20: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"interview_successful","meta":{"friendly_name":"innr_flex_light_1","model":"FL 130 C","vendor":"Innr","description":"Color Flex LED strip","supported":true}}'
siclark wrote:Wouldn't the led strip pair with your hue hub? Or is this more just playing to see what's possible?
zigbee2mqtt/Aqara/Master
