Bug?
Mon Feb 10, 2020 1:56 pm
Bildhauer offline
Re: Bug?
Hello,
I was asking for a download opportunity to be able to downgrade to version 1.028, as version 1.038 is not working at all.
Thanks in advance!
Best regards
Bildhauer
Mon Feb 10, 2020 2:35 pm
Re: Bug?
Yes... on that page are all the old releases....
Tue Feb 11, 2020 4:08 am
Bildhauer offline
Re: Bug?
Downgrading brings the following log messages/ errors:
Stopping plugin Z-Wave Scene Controller (pid 531)
Z-Wave Scene Controller Debug Stop processing trigger Büro Licht an
Z-Wave Scene Controller Debug Stop processing trigger Büro Licht aus
Z-Wave Scene Controller Debug Stop processing trigger Büro Licht DUNKLER
Z-Wave Scene Controller Debug Stop processing trigger Büro Licht HELLER
Z-Wave Scene Controller Debug Stop processing trigger Erdgeschoss + Büro komplett GOOD NIGHT
Z-Wave Scene Controller Debug Stop processing trigger Erdgeschoss komplett GOOD NIGHT
Z-Wave Scene Controller Debug Stop processing trigger Wohnzimmer Licht AN
Z-Wave Scene Controller Debug Stop processing trigger Wohnzimmer Licht AUS
Z-Wave Scene Controller Debug shutdown called
Stopped plugin Z-Wave Scene Controller
Downgrading plugin Z-Wave Scene Controller to older version 1.0.28 (previous version moved to trash)
Loading plugin "Z-Wave Scene Controller 1.0.28"
Starting plugin "Z-Wave Scene Controller 1.0.28" (pid 5711)
Started plugin "Z-Wave Scene Controller 1.0.28"
Z-Wave Scene Controller Debug startup called -- subscribing to all incoming Z-Wave commands
Z-Wave Scene Controller Debug Start processing trigger Büro Licht an
Z-Wave Scene Controller Debug Start processing trigger Büro Licht aus
Z-Wave Scene Controller Debug Start processing trigger Büro Licht DUNKLER
Z-Wave Scene Controller Debug Start processing trigger Büro Licht HELLER
Z-Wave Scene Controller Debug Start processing trigger Erdgeschoss + Büro komplett GOOD NIGHT
Z-Wave Scene Controller Debug Start processing trigger Erdgeschoss komplett GOOD NIGHT
Z-Wave Scene Controller Debug Start processing trigger Wohnzimmer Licht AN
Z-Wave Scene Controller Debug Start processing trigger Wohnzimmer Licht AUS
Z-Wave received "Zwischenstecker Küche Spülmaschine" power load to 4.04 W
Z-Wave received "Taster Büro" scene 5 (0005)
Z-Wave Scene Controller Debug -----
Z-Wave Scene Controller Debug Central Scene Command received:
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 85 05 5B 03 52 00 05 FF
Z-Wave Scene Controller Debug Node: 133
Z-Wave Scene Controller Debug Button: 5
Z-Wave Scene Controller Debug ActionID: 0
Z-Wave Scene Controller Debug Action: Click
Z-Wave Scene Controller Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 202, in zwaveCommandReceived
File "plugin.py", line 251, in triggerEvent
KeyError: key id 812343885 not found in database
11. Feb 2020 at 11:00:46
Z-Wave received "Taster Büro" scene 1 (0001)
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 85 05 5B 03 53 00 01 FF
Z-Wave Scene Controller Debug Button: 1
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 74.24 W
11. Feb 2020 at 11:01:12
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 70.60 W
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 74.54 W
Z-Wave received "Zwischenstecker Aquarium Licht Wohnzimmer" power load to 98.73 W
11. Feb 2020 at 11:01:50
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 85 05 5B 03 54 00 05 FF
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 70.61 W
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 85 05 5B 03 55 00 01 FF
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 85 05 5B 03 56 00 05 FF
Upgrading back to v1.038 it looks like this:
Stopping plugin Z-Wave Scene Controller (pid 5711)
Upgrading plugin Z-Wave Scene Controller to newer version 1.0.38 (previous version moved to trash)
Loading plugin "Z-Wave Scene Controller 1.0.38"
Starting plugin "Z-Wave Scene Controller 1.0.38" (pid 5748)
Started plugin "Z-Wave Scene Controller 1.0.38"
So no action is triggered by using the buttons …
Tue Mar 10, 2020 3:54 pm
Re: Bug?
Ok, so I can't see any problems with 1.0.38 - it's the same version I'm using, i've compared the code line by line and nothing in it that changed from .28 relates to anything about executing the triggers.
However, i'm looking at the code of 1.0.28 against your post above.
That line 251 is trying to find a device in your database with ID 812343885, which from your screenshot looks to be "Taster Buro".
If you go in Indigo to the Devices table and find "Taster Buro" I suspect the ID won't be 812343885.
Can you edit the trigger "Buro Licht An" and re-select "Taster Buro" and SAVE the trigger, then try again?
Peter
Fri Apr 10, 2020 12:36 pm
Bildhauer offline
Re: Bug?
Hello Peter,
I did as suggested without any effect.
Best regards
Bildhauer
Fri Apr 17, 2020 1:33 pm
Re: Bug?
Ok, next stage is to start deleting things.
Make a note of each of your Scene Controller triggers, then delete the triggers.
Restart the plugin to be sure.
Then recreate the triggers.
Peter
