ZooZ Zen25 Double Plug
Fri Nov 29, 2019 10:48 am
aldera offline
Does anyone have at the fairly new Zooz ZEN25 (double plug module) that they're currently using under Indigo? I see that the ZEN15 and ZEN20 are supported and wondering if it'll work without having a new device definition. Thanks.
Ralph
Fri Nov 29, 2019 11:56 am
Re: ZooZ Zen25 Double Plug
Hi Ralph,
I just checked and we do have a device info report submitted by someone that has one. It sounds like only 1 outlet is controllable from Indigo currently, so we'll look at adding a definition to get both outlets working correctly.
Sat Nov 30, 2019 12:06 pm
aldera offline
matt (support) wrote:
Hi Ralph,
Great. I'lll probably get one then and look for the update in your next release.
Thanks.
Ralph
Mon Dec 02, 2019 4:21 pm
aldera offline
Hi Ralph,
Here's the logging for the sync of my device in case the model number is different:
  Z-Wave                          Syncing - started for "073 - Relay Power Switch"
   Z-Wave                          Syncing - retrieved module neighbors list: 2, 6, 9, 10, 16, 25, 37, 38, 39, 41, 47, 48, 50, 53, 58, 66, 70
   Z-Wave                          Syncing - assigning return route to "073 - Relay Power Switch"
   Z-Wave                          Syncing - assigned return route
   Z-Wave                          Syncing - retrieved manufacture and model names: Zooz - 027A, Relay Power Switch - A000A003
   Z-Wave                          Syncing - retrieved protocol version 5.03, app version 2.00
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
   Z-Wave                          Syncing - retrieved command classes: 20v1 60v4 25v1 86v1 27v1 6Cv1 72v1 8Ev1 70v1 71v1 32v4 73v1 55v1 59v1 5Av1 85v1 7Av1 5Ev1 9Fv1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave                          Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01)
   Z-Wave                          Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E 25 32 6C 9F], 2:[5E 85 59 8E 25 32 6C 9F], 3:[5E 85 59 8E 25 32 6C 9F]
   Z-Wave                          Syncing - retrieved group 1 associations: []
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - added group 1 association to interface
   Z-Wave                          Syncing - created device "073 - Relay Switch"
   Z-Wave                          Syncing - created device "073 - Relay Switch 2"
   Z-Wave                          Syncing - created device "073 - Relay Switch 3"
   Z-Wave                          Syncing - complete
And here's the logging when hitting the button on the Configure panel:
Indigo Z-Wave Version: 7.4.0
Node ID: 73
Model: Relay Power Switch
Model ID: A000A003
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 5.03
Application Version: 2.00
Model Definition Version: 0
Library Type: 3
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v4 25v1 86v1 27v1 6Cv1 72v1 8Ev1 70v1 71v1 32v4 73v1 55v1 59v1 5Av1 85v1 7Av1 5Ev1 9Fv1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01)
Multi-Endpoint Classes: 1:[5E 85 59 8E 25 32 6C 9F], 2:[5E 85 59 8E 25 32 6C 9F], 3:[5E 85 59 8E 25 32 6C 9F]
Features: routing, beaming, energyMeter
Neighbors: 2, 6, 9, 10, 16, 25, 37, 38, 39, 41, 47, 48, 50, 53, 58, 66, 70
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Ralph
Tue Dec 24, 2019 8:35 am
dduff617 offline
i just bought a few of these. When including in Indigo, they come through as three devices. One controls the right outlet, one controls both outlets, and the third contols nothing. I would also like to see support for this.
Mon Jan 20, 2020 6:18 pm
Espressomatic offline
I've been using this outlet since November - I must have submitted a duplicate sometime in December. Coincidentally, I didn't see this forum post AND I had been using port #2 with my Christmas tree. I didn't notice until today that the main device controls both outlets at once - or maybe I'd just forgotten since November. :)
The outlet is now pulling aquarium duty for my daughter's newly set up tank, with one outlet dedicated to lighting and the other to a solenoid on a CO2 tank. Thankfully it's OK to have both turn on at once right now, but looking forward to full support nevertheless.
Fri Feb 07, 2020 2:45 pm
Indigo 7.4.1 is now available and includes support for the Zooz Dimmer Switch (ZEN27), Relay Switches (ZEN21, ZEN26), and Double Plug (ZEN25).
Wed Feb 26, 2020 8:45 am
roquej offline
Is there a way to turn off the "energy reporting"?
JP
Wed Feb 26, 2020 9:35 am
aldera offline
JP
If you go to "Edit Device Settings" for the device, there's a textbox labeled, "Periodic Energy Reports." If you enter "0", it should disable reporting.
Wed Feb 26, 2020 9:53 am
roquej offline
Thank you for the suggestions. A quick question:
Will this option removes the update in the log or it just turns reporting off, which will affect the total details?
JP
Wed Feb 26, 2020 10:23 am
That will reduce the number of reports sent by the module.
Wed Feb 26, 2020 12:16 pm
roquej offline
Thank you.
I increased the number to 1200, as making it zero doesn't't work for me. It gives me an error and you can't close the dialog.
JP
Thu Apr 16, 2020 7:10 am
roquej offline
It seems the "Periodic power reports" and "Periodic energy reports" parameters don't do anything. Tried setting to 0 (disable) and I get an error. See the picture enclosed.
What am I doing wrong?
JP
Screen Shot 2020-04-16 at 7.29.25 AM.png (102.93 KiB) Viewed 2312 times
Thu Apr 16, 2020 11:07 am
aldera offline
JP
Looks like the range limits of 30 to 2678400 for each parameter is overriding the ability to enter any number below 30, including the 0. I get the same results.
RS
Thu Apr 16, 2020 11:11 am
roquej offline
JP
RS
Yep, and it doesn't matter what number I put in, get status reports every 2 min or so.
JP
