Hi kw123,
After upgrading to the Catalina version, I've twice had my events reset. The first time I re-set them up, and found that they disappeared the day later. All events are cleared, no IP devices. Help!
2020-01-18 00:19:01.719 ERROR Plugin.dorunConcurrentThread --> setup config, save then a manual reload of plugin
2020-01-18 00:19:01 --> while loop break stopping ... quitNOW was: please setup config , waiting
2020-01-18 00:19:01.729 ERROR Plugin.dorunConcurrentThread --> you have 2 minutes to fix config, before restart
2020-01-18 00:19:01.729 ERROR Plugin.dorunConcurrentThread --> do a manual reload of plugin
2020-01-18 00:19:01 stopConcurrentThread called 2
2020-01-18 00:19:04 ========================= initializing ==============================================
2020-01-18 00:19:04 !!!!INFO ONLY!!!! logger enabled for THREADDEBUG !!!!INFO ONLY!!!!
2020-01-18 00:19:04 !!!!INFO ONLY!!!! logger enabled for DEBUG !!!!INFO ONLY!!!!
2020-01-18 00:19:04 !!!!INFO ONLY!!!! logger enabled for INFO !!!!INFO ONLY!!!!
2020-01-18 00:19:04 !!!!INFO ONLY!!!! logger enabled for WARNING !!!!INFO ONLY!!!!
2020-01-18 00:19:04.874 ERROR Plugin.__init__ !!!!INFO ONLY!!!! logger enabled for ERROR !!!!INFO ONLY!!!!
2020-01-18 00:19:04.874 CRITICAL Plugin.__init__ !!!!INFO ONLY!!!! logger enabled for CRITICAL !!!!INFO ONLY!!!!
2020-01-18 00:19:05 leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
2020-01-18 00:19:05 indigo variables initialized
2020-01-18 00:19:05 getting password
2020-01-18 00:19:05 get password done; checking if FING is installed
2020-01-18 00:19:07 fing install check done
2020-01-18 00:19:08 loaded indigo data
2020-01-18 00:19:08 network info: {'netWorkId': '10.66.0.0', 'broadcast': '10.66.0.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '10.66.0.1 - 10.66.0.254'}
2020-01-18 00:19:08 ifind plugin: com.corporatechameleon.iFindplugBeta
2020-01-18 00:19:08 MAP2Vendor initializing
2020-01-18 00:19:09 FING initializing parameters
startfing L:237 Lv:20 ========= start @ 2020-01-18 00:19:10.670348 ===========
startfing L: 74 Lv:20 into doFingV5 with yearTag: 2020/01, netTag: 10., version: 5.4; opsys: 10.15
2020-01-18 00:19:12 FING waiting for first data
startfing L: 98 Lv:20 fing.bin launched
2020-01-18 00:19:32 FING initializing checking if output created, old timeStamp:1579324731.69; new timeStamp:1579324756.3
2020-01-18 00:19:32 FING initialized .. created new data waiting ~ 1 minute for stable operation
2020-01-18 00:19:32 FING pids after step3 = ['26915']
2020-01-18 00:19:32 (re)started FING
2020-01-18 00:19:32 settings: iDevicesEnabled False
2020-01-18 00:19:32 settings: inbetweenPingType parallel
2020-01-18 00:19:32 settings: wifiRouter 0
2020-01-18 00:19:32 settings: wait seconds between cycles 1
2020-01-18 00:19:32 settings: password entered True
2020-01-18 00:19:32 settings: debugLevel []
2020-01-18 00:19:32 settings: FINGSCAN will scan Network 10.66.0.... # fixed bits in ip range:24
2020-01-18 00:19:32
2020-01-18 00:19:32
EVENT defs::::::::::::::::::
2020-01-18 00:19:32 getting vendor info
2020-01-18 00:20:15 FINGSCAN initialized
2020-01-18 22:08:32 stopConcurrentThread called 1
2020-01-18 22:08:32 --> exception StopThread triggered ... stopped, quitNOW was: please setup config
2020-01-18 22:08:32 stopConcurrentThread called 2
2020-01-18 22:08:32 shutdown called
2020-01-18 22:09:33 ========================= initializing ==============================================
2020-01-18 22:09:33 !!!!INFO ONLY!!!! logger enabled for THREADDEBUG !!!!INFO ONLY!!!!
2020-01-18 22:09:33 !!!!INFO ONLY!!!! logger enabled for DEBUG !!!!INFO ONLY!!!!
2020-01-18 22:09:33 !!!!INFO ONLY!!!! logger enabled for INFO !!!!INFO ONLY!!!!
2020-01-18 22:09:33 !!!!INFO ONLY!!!! logger enabled for WARNING !!!!INFO ONLY!!!!
2020-01-18 22:09:33.693 ERROR Plugin.__init__ !!!!INFO ONLY!!!! logger enabled for ERROR !!!!INFO ONLY!!!!
2020-01-18 22:09:33.694 CRITICAL Plugin.__init__ !!!!INFO ONLY!!!! logger enabled for CRITICAL !!!!INFO ONLY!!!!
2020-01-18 22:09:35 leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
2020-01-18 22:09:36 indigo variables initialized
2020-01-18 22:09:36 getting password
2020-01-18 22:09:36 get password done; checking if FING is installed
2020-01-18 22:09:40 fing install check done
2020-01-18 22:09:44 loaded indigo data
2020-01-18 22:09:44 network info: {'netWorkId': '10.66.0.0', 'broadcast': '10.66.0.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '10.66.0.1 - 10.66.0.254'}
2020-01-18 22:09:44 ifind plugin: com.corporatechameleon.iFindplugBeta
2020-01-18 22:09:44 MAP2Vendor initializing
2020-01-18 22:09:44 MAP2Vendor downloading raw files, will take some minutes
2020-01-18 22:09:44 /usr/bin/curl -L https://standards.ieee.org/develop/regauth/oui/oui.csv | tail -n +2 | cut -d',' -f'2,3' | sed 's/"//'> '/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/mac2Vendor/oui' &
2020-01-18 22:09:44 /usr/bin/curl -L https://standards.ieee.org/develop/regauth/oui28/mam.csv | tail -n +2 | cut -d',' -f'2,3' | sed 's/"//'> '/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/mac2Vendor/mam' &
2020-01-18 22:09:44 /usr/bin/curl -L https://standards.ieee.org/develop/regauth/oui36/oui36.csv | tail -n +2 | cut -d',' -f'2,3' | sed 's/"//'> '/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/mac2Vendor/oui36' &
2020-01-18 22:09:44 MAP2Vendor initializing still waitinmg for download
2020-01-18 22:09:48 FING initializing parameters
startfing L:237 Lv:20 ========= start @ 2020-01-18 22:09:49.490759 ===========
2020-01-18 22:09:50 FING waiting for first data
2020-01-18 22:10:10 FING initializing checking if output created, old timeStamp:1579403298.97; new timeStamp:1579403395.74
2020-01-18 22:10:10 FING initialized .. created new data waiting ~ 1 minute for stable operation
2020-01-18 22:10:10 FING pids after step3 = ['61594']
2020-01-18 22:10:10 (re)started FING
2020-01-18 22:10:10 settings: iDevicesEnabled False
2020-01-18 22:10:10 settings: inbetweenPingType parallel
2020-01-18 22:10:10 settings: wifiRouter 0
2020-01-18 22:10:10 settings: wait seconds between cycles 1
2020-01-18 22:10:10 settings: password entered True
2020-01-18 22:10:10 settings: debugLevel []
2020-01-18 22:10:10 settings: FINGSCAN will scan Network 10.66.0.... # fixed bits in ip range:24
2020-01-18 22:10:10
2020-01-18 22:10:10
2020-01-18 22:10:10 getting vendor info
2020-01-18 22:10:52 FINGSCAN initialized
2020-01-18 22:13:17 stopConcurrentThread called 1
2020-01-18 22:13:18 --> exception StopThread triggered ... stopped, quitNOW was: please setup config
2020-01-18 22:13:18 stopConcurrentThread called 2
2020-01-18 22:13:18 shutdown called
2020-01-18 22:13:21 ========================= initializing ==============================================
2020-01-18 22:13:21 !!!!INFO ONLY!!!! logger enabled for THREADDEBUG !!!!INFO ONLY!!!!
2020-01-18 22:13:21 !!!!INFO ONLY!!!! logger enabled for DEBUG !!!!INFO ONLY!!!!
2020-01-18 22:13:21 !!!!INFO ONLY!!!! logger enabled for INFO !!!!INFO ONLY!!!!
2020-01-18 22:13:21 !!!!INFO ONLY!!!! logger enabled for WARNING !!!!INFO ONLY!!!!
2020-01-18 22:13:21.481 ERROR Plugin.__init__ !!!!INFO ONLY!!!! logger enabled for ERROR !!!!INFO ONLY!!!!
2020-01-18 22:13:21.481 CRITICAL Plugin.__init__ !!!!INFO ONLY!!!! logger enabled for CRITICAL !!!!INFO ONLY!!!!
2020-01-18 22:13:22 leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
2020-01-18 22:13:22 indigo variables initialized
2020-01-18 22:13:22 getting password
2020-01-18 22:13:22 get password done; checking if FING is installed
2020-01-18 22:13:24 fing install check done
2020-01-18 22:13:26 loaded indigo data
2020-01-18 22:13:26 network info: {'netWorkId': '10.66.0.0', 'broadcast': '10.66.0.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '10.66.0.1 - 10.66.0.254'}
2020-01-18 22:13:26 ifind plugin: com.corporatechameleon.iFindplugBeta
2020-01-18 22:13:26 MAP2Vendor initializing
2020-01-18 22:13:26 FING initializing parameters
startfing L:237 Lv:20 ========= start @ 2020-01-18 22:13:28.052064 ===========
2020-01-18 22:13:30 FING waiting for first data
2020-01-18 22:13:50 FING initializing checking if output created, old timeStamp:1579403575.67; new timeStamp:1579403613.7
2020-01-18 22:13:50 FING initialized .. created new data waiting ~ 1 minute for stable operation
2020-01-18 22:13:50 FING pids after step3 = ['62509']
2020-01-18 22:13:50 (re)started FING
2020-01-18 22:13:50 settings: iDevicesEnabled False
2020-01-18 22:13:50 settings: inbetweenPingType parallel
2020-01-18 22:13:50 settings: wifiRouter 0
2020-01-18 22:13:50 settings: wait seconds between cycles 1
2020-01-18 22:13:50 settings: password entered True
2020-01-18 22:13:50 settings: debugLevel []
2020-01-18 22:13:50 settings: FINGSCAN will scan Network 10.66.0.... # fixed bits in ip range:24
2020-01-18 22:13:50
2020-01-18 22:13:50
2020-01-18 22:13:50 getting vendor info
2020-01-18 22:14:25 FINGSCAN initialized
self.EVENTS=json.loads(self.pluginPrefs["EVENTS"])
except:
self.EVENTS = {}
indigo.devices[int(self.EVENTS[n]["IPdeviceMACnumber"][nDev])]
except:
self.indiLOG.log(40, u"cleanupEVENTS removing device from evants as indigo device does not exist:"+ unicode(self.EVENTS[n]["IPdeviceMACnumber"][nDev]) )
self.EVENTS[n]["IPdeviceMACnumber"][nDev] = "0"
