Insteon Garage Door will open but not close
Mon Dec 30, 2019 10:20 pm
captcurrent offline
OK I don't have the exact model number but I have an insteon garage for opener/closer for about 6 years (which is probably part of the problem
It will open the door but won't close.
[Sent INSTEON "garage door" off
Sent INSTEON "garage door" status request (received input sensor: open)
Sent INSTEON "garage door" status request (received output relay: off)
Action Group Close Garag Door
I can repeat as often as Ii want with same results... Any thoughts beyond whipping out the charge card?
Tue Dec 31, 2019 10:51 am
captcurrent offline
Re: Insteon Garage Door will open but not close
I was wrong doesn't open either
guess another insteon bit the dust though it seems strange it is responding and the green pilot light is on
Fri Jan 03, 2020 9:25 am
captcurrent offline
any thoughts??
Fri Jan 03, 2020 11:07 am
captcurrent offline
Re: Insteon Garage Door failed
Changed the I/O module with a spare I had.... no joy.
Fri Jan 03, 2020 11:13 am
If you turn it off and it shows off and you turn it on and it shows on, then there may be something wrong with the wiring. I'd recheck the wires between the I/O Linc and the opener to make sure they are still intact. Also check the wires at the opener to make sure something hasn't worked loose or something.
Fri Jan 03, 2020 5:06 pm
captcurrent offline
well on my 3rd I/O. now to the point where I select if I select button 1 when it is closed. it opens. if it is open I select button twice and it closes from the device
I can set an active group to open the door. but not close its since I cant figure out how tp replicate the off
Fri Jan 03, 2020 5:38 pm
Sorry, not following. Can you state more clearly what's going on now?
Sat Jan 04, 2020 9:49 am
captcurrent offline
Well 3rd I/O device the charm. I have never had much luck with them
It been a while since the original installation but I don't remember need a two step command to control the door
It isn't pretty but it works
See attachment
Screenshot 2020-01-04 10.44.56.png (503.1 KiB) Viewed 2887 times
Sun Jan 05, 2020 1:19 pm
You shouldn't need two steps. Did you configure the I/O Linc as specified in the first 3 steps of this how-to?
Wed Jan 08, 2020 8:05 am
captcurrent offline
No I didn't I was re utilizing an I/O unit I have changed the stating as set forth in this. Thanks
Fri May 07, 2021 9:19 am
captcurrent offline
Ok now that I am back where the garage is , I have been attacking this issue again.
The link your provided to the discussion on the controller is a newer one then I have
My older setup uses a Insteon2450
Can you teller what terminals the wire from the Moto and from the magnetic switch go into??
Sat May 08, 2021 3:04 pm
I'm confused – are you replacing an existing I/O-Linc with another one?
If you aren't, then what hardware did you use and are you using now?
If you are, then just wire it up exactly the same way the original was wired.
Make sure you follow Jay's instructions above and those 3 steps (including uploading the right settings to the I/O-Linc).
Sun May 09, 2021 7:14 am
captcurrent offline
in my earlier posts you will se3 that the opening us not functioning as expected. The controller i bought quite a while back was based on a 2450. I have several of those from other controllers that i am not using as they were passed by newer systems. The link provided does not clearly show the wiring sequence. I want to verify that is is correct. I would tend to think the number on the 2540have some importance or they wouldn’t be there Agai. i am trouble shooting I have found that insteon devices have a limited life
Fri May 14, 2021 12:17 pm
I'm sorry, but I'm having a hard time understanding your post.
The wiring sequence shouldn't change when replacing an I/O-Linc.
What is the specific model number of both your old and new/current modules?
Fri May 14, 2021 4:24 pm
captcurrent offline
i am using an insteaon 2450. The contacts on those are numbered. the picture in your link on your attachment show sun numbered contact s. From the crude view provided on the link it also appears the wire from the contact switch on the bottom of the door all goes into one contact.
Users browsing this forum: No registered users and 22 guests
