Kylie Minogue
Custom image to display when screen is unused rather than dimming (I'm thinking a SecuritySpy feed full screen but some would be nice to just have a slideshow of different pics)
Why did you write your feature request twice?
There have been a couple of requests for the dimmed screen -- for instance, a clock and a specific control page. I am kind of thinking of supporting those three options (dim only, clock, control page) which should allow coverage of nearly all the requests. I'm trying to decide, too, if we support a separate "no activity, go to XYZ (presumably a start page) control page and dim".
It would be nice to be able to save more than one Indigo server setting and to be able to switch between them in DomoPad v2.
I don't think it will be implemented up front, but I did put some provisions in to support this in the future. It would be implemented kind of as a "save" and "recall" settings (at least select settings). Then most likely you would select that saved settings/profile/whatever it is called at the top left of the navigation drawer in the header (similar to where you can manually select home/away now).
Adam
