Help converting AppleScript with iTunes to Python with Music
Mon Dec 09, 2019 3:49 pm
kcossabo offline
Posted this in the wrong forum...
Help me please? I am sure there is massive GREAT reasons for a program that only runs on a Mac to stop supporting the Apple Scripting language, but, I need assistance with getting my whole house audio working again after mistakenly upgrading to the crippled 7.4
Below is a simple tell iTunes to play (I have one to pause as well) music.... .is it easy in Python??? Goggling for Python control of Apple Music results in strange music sold in iTunes and apps that write music, not the code.
Thank you in advance.
# Indigo no longer supports execution of embedded AppleScripts. For help
# translating AppleScripts to python see: http://indigodomo.com/applescript
# The original AppleScript was:
# tell application "iTunes"
# if player state is stopped then
# play playlist "Vinal Recordings - My Fav"
# set shuffle enabled to true
# -- set shuffle in playlist "2 stars and greater" to true
# else
# stop
# end if
# end tell
Mon Dec 09, 2019 4:19 pm
kcossabo offline
Re: Help converting AppleScript with iTunes to Python with M
Is it this simple?
Put the AppleScript into a Script file via the Script Editor
Execute the file verse embedded???
Mon Dec 09, 2019 4:30 pm
Korey offline
kcossabo wrote:
Is it this simple?
Yes it is!
Korey
Mon Dec 09, 2019 5:40 pm
As we say on the page linked in the comments of your script, scripts that don't target IndigoServer will continue to run if executed externally.
Note that we've been warning of this change (and describing why) for a couple of years, and we've gone out of our way to make sure that everywhere we discuss 7.4 mentions that AppleScript support to the Indigo Server would be deprecated. This should not come as a surprise to anyone who simply reads through the release information or does the most cursory search on the these forums.
Mon Dec 09, 2019 6:56 pm
kcossabo offline
IMHO
The information has grown, commented, and have limited top level knowledge.
‘AppleScript no longer supported’
AppleScript support only via external file.
There is a difference. Stating you are moving from AppleScript to python, should have a clear, but full support via a file.
IMHO, first sticky should be, move your script to a file, and you will continue as you wee.
My humble opinion.
Mon Dec 09, 2019 7:29 pm
The article linked to in the script is very accurate and gets right to the point.
Yes - and one does not equal the other. The article linked explains the difference.
That is not correct. AppleScripts that target the Indigo Server no longer work, which is literally what the first sentence says, and is repeated in the first sentence of the second paragraph. One option is to convert those types of scripts to Python, but there are other recommendations in that article. Many of the requested script conversions didn't need any script at all because there are now lots of 3rd party plugins that can do many of the things AppleScripts were used for before Indigo 5.
Again, that is not correct. AppleScripts that target the Indigo Server no longer work. And most Indigo AppleScripts do target the server. The one you posted above happens to (happily) be one one that will work as an external script because it doesn't target the Indigo Server (tell application IndigoServer).
