siclark wrote:For those who have these setup already what have you done for power requirements? Enough to power all on full brightness or a % of that?
I still need to order my power supply.
mundmc wrote:siclark wrote:For those who have these setup already what have you done for power requirements? Enough to power all on full brightness or a % of that?
Last night I tested 4x 300 light strips with a 60A supply- no problems and flirting with adding a 5th strip. I can say voltage drop was easy to identify, but only with 3x strips in serial.
virgahyatt wrote:mundmc wrote:siclark wrote:For those who have these setup already what have you done for power requirements? Enough to power all on full brightness or a % of that?
Which brand strips are you using? Cause I see voltage drop with mine after just adding a second one. Though only when I push the brightness up.
noel1983 wrote:siclark wrote:For those who have these setup already what have you done for power requirements? Enough to power all on full brightness or a % of that?
The price difference of the power supplies isn't that much so for me I based it on convenience of location, so I've got 2 x 20A each powering 2 x 150 led strips which is more than sufficient.
mundmc wrote:virgahyatt wrote:mundmc wrote:siclark wrote:For those who have these setup already what have you done for power requirements? Enough to power all on full brightness or a % of that?
These guys:
CHINLY 16.4ft WS2812B Individually Addressable LED Strip Light 5050 RGB SMD 300 Pixels Dream Color Waterproof IP67 Black PCB 5V DC (Black PCB 16.4ft 300leds waterproof) https://www.amazon.com/dp/B01LSF4Q0A/re ... 2DbEXPF2R2
MunDMC
