Wed Nov 13, 2019 4:36 am
Busta999 offline
Autolog happened again
Noticed the Guest Bedroom running low - too low
It appears that the TRV device has Heat Turned Off when I would expect it to be On
MacOs 10.12.6
Indigo 7.4.0
TRV Plugin 1.3.1
Indigo TRV Mal 1.jpeg (105.81 KiB) Viewed 686 times
Indigo - TRV Mal 2.jpeg (124.76 KiB) Viewed 686 times
Indigo Config - TRV 1.jpeg (184.05 KiB) Viewed 685 times
Indigo Config - TRV 2.jpeg (189.03 KiB) Viewed 685 times
Indigo Config - TRV 3.jpeg (93.39 KiB) Viewed 685 times
Wed Nov 13, 2019 4:44 am
Busta999 offline
It looks like the Setpoint for each schedule is getting lost between the config screen and the actual settings?
Wed Nov 13, 2019 5:06 am
autolog offline
I think I have a fix for this - At some point today I will PM you a link to a test version that should hopefully fix this. :)
Wed Nov 13, 2019 5:07 am
autolog offline
I don't understand what you mean - what is getting lost? :?
Wed Nov 13, 2019 5:08 am
Busta999 offline
Autolog
Many thanks - very much appreciated - I am trying to bottom these out before I start working away from home again that will mean I have limited ability to resolve.
She who must be obeyed will not be able to get into Indigo :-)
My life will be painful at weekends ....
Wed Nov 13, 2019 5:12 am
Busta999 offline
The Custom States show set points as Not Set
But when you select the Edit Device Settings it does have Set Points set.
I think I know how /why this may be happening. Looking into it now - it could be a Guest Mode I am using that sets the Guest rooms up for visitors..
Wed Nov 13, 2019 6:29 am
Busta999 offline
May or may not be significant.
All 3 Spirits that have gone rouge - Report that the Valve is open 100% while the valve is actually at 0% are ALL firmware 0.16
My 0.15s have not yet failed.
If anyone else has had a Spirit go rouge as described above can you confirm the firmware version?
The ONLY way I have found to address this issue so far is to physically remove batteries and re-insert them.
Autolog is working on a software workaround.
Thu Nov 14, 2019 8:42 am
Busta999 offline
Running the Test 1.4.0 plugin
Adjusted 4 of the Spirit TRV settings yesterday after the rouge Sprits reported earlier.
Dropped them down to a simple 1 Schedule below:-
Indigo - TRV Scheduling issue.jpeg (148.48 KiB) Viewed 670 times
I had expected to just maintain a steady 17C throughout the day.
Instead it dropped all four rooms to a target set point of 8C.
I found the rooms this morning at 15C then did a manual override on the Thermostats - that stabilised things.
But I suspect that the TRV Plugin will force them back to 8C again.
Any suggestions/pointers on what I have done wrong here and how to fix it?
Thu Nov 14, 2019 12:41 pm
autolog offline
Busta999 wrote:
... Any suggestions/pointers on what I have done wrong here and how to fix it?
I don't think it is anything you have done :)
Continuing debug discussion via iMessage. :)
Sat Nov 16, 2019 8:16 am
shapa offline
I've got similar issue - floor heating thermostat keeps resetting to 5C :)
BTW added "Generic Thermostat v2" manually to the XML file, so, for now, the only real issue it an electric floor one.
Any progress on enabling "smart thermostats self-management" - i.e. only to specify heat points (and enable global heating device if required)?
Sat Nov 16, 2019 2:19 pm
autolog offline
I haven't made an progress on that at the moment and can't offer an ETA. :|
Mon Nov 25, 2019 11:06 am
Busta999 offline
Is it at all possible you set the target set point to include a decimal point in it, i.e. 18.5c 0r 21.5c
I have done a test on a Spirit and if I set TRV target to 18.5c I get weird behaviour, as soon as I set to a whole number it works ok.
My issues with this have stopped since I kept to whole digits...
Mon Nov 25, 2019 11:09 am
Busta999 offline
Over the last week I have had three Rogue Spirits.
i.e. they appear to be fully functioning but are in fact remaining open or closed while reporting something different.
The one I just found, in the guest bathroom, had a lighten and was stuck in INS and unresponsive to button presses.
Taking out the batteries and reseating them fixed the problem.
I suspect that I may just, once a week go around and reset the batteries to ensure they continue to operate properly.
Need to think of a better way of doing it...
Mon Nov 25, 2019 12:49 pm
siclark offline
There watchdog plugin is a good one. Set for 30 minute checks and it send a pushover alert when a trv misses an update. I presume it's not responding to status requests when in that state?
Mon Nov 25, 2019 1:12 pm
autolog offline
If a wakeup is missed, the plugin recognises that and flags the device with a timer icon. I guess it could more usefully set a state (which it doesn't at the moment). :)
