It would not let me change it - so I factory reset the quad and trashed all the indigo stuff I had and started over fresh.
The new add info below - I was able to turn on scene commands but it is still not working - when I press any button indigo does not seem to get / see any Z-wave commands - I'm very confused at this point
Jan 24, 2021 at 8:07:52 AM
Z-Wave controller included module: 068 - Basic Wall Controller
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "068 - Basic Wall Controller"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 9, 12, 14, 19, 20, 21, 22, 25, 26, 31, 32, 33, 34, 46, 47, 48
Z-Wave Syncing - assigning return route to "068 - Basic Wall Controller"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0371, NanoMote Quad (ZWA003) - 01020003
Z-Wave Syncing - retrieved protocol version 4.61, app version 1.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 55v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 20v1 6Cv1 70v1 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: 80 84 85 86 70 72 73 59 5A 5B 7A
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 0 minutes
Z-Wave Syncing - device "068 - Basic Wall Controller" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Syncing - retrieved group 7 associations: []
Z-Wave Syncing - retrieved group 8 associations: []
Z-Wave Syncing - retrieved group 9 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - module returned parameter 32 instead of parameter 41 "Enable scene commands" (ignoring)
Z-Wave Syncing - failed to retrieve parameter 41 "Enable scene commands" (skipping)
Z-Wave Syncing - retrieved parameter 43 "Enable low battery buzzer" is false
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "068 - NanoMote Quad (ZWA003)"
SQL Logger creating table device_history_490983781 for "068 - NanoMote Quad (ZWA003)"
Z-Wave Syncing - complete
SQL Logger adding column "batterylevel_ui" to table device_history_490983781 ("068 - NanoMote Quad (ZWA003)")
Z-Wave device "068 - NanoMote Quad (ZWA003)" parameter 41 "Enable scene commands" changed to false
Z-Wave device "068 - NanoMote Quad (ZWA003)" parameter 41 "Enable scene commands" changed to true
