Decent espresso
Sat Oct 05, 2019 9:05 pm
hamw offline
Decent espresso
I thought the community would be interested in this novel espresso machine. It is loaded with sensors and is software controlled with incredible precision. I recently purchased one. Lots of interesting things going on.
The YouTube link is a good place to start…
https://youtu.be/A4BsE0uXxBE
http://decentespresso.com/
Sun Oct 06, 2019 5:41 am
Re: Decent espresso
Looks nice. I like their sensibilities--an espresso machine that nice which is "decent".
Sun Oct 06, 2019 11:05 am
peszko offline
Re: Decent espresso
Can it be automated? From the video its looks like it can't?
I wouldn't mine a machine that can make a perfect espresso right when I wake up.
Sun Oct 06, 2019 7:55 pm
hamw offline
Re: Decent espresso
Automation may be coming. Look at the Instagram account… Lots of fun things in the works.
https://instagram.com/decentespressomachines/
That said, since one wants espresso hot might be tough if you were just a minute late getting to the kitchen… :-)
Sun Oct 06, 2019 8:37 pm
Re: Decent espresso
I totally disagree.
Espresso is only really good and satisfying if it’s done with your own hands That’s one of the areas I shall not automate. [HOT BEVERAGE]️
Sun Oct 06, 2019 9:31 pm
peszko offline
Re: Decent espresso
The first thing I do in the morning is fire up my espresso machine. Takes a bit to warm up. Now thinking about it, this might be worth automating. Hmmmmmmm.....
Any suggestions on z-wave 20A GFI outlet? (Yes, mine requires 20A to run and it is close enough to the sink to require GFI)
Sun Oct 06, 2019 10:54 pm
Re: Decent espresso
are you sure about 20amps? That would require a special plug / outlet. Normal plugs only go up to 10/15?
ps am using a Smart Switch 6 (ZW096), that shows max 15amps switching
Mon Oct 07, 2019 5:11 am
peszko offline
Re: Decent espresso
Quite sure. It is a special 20A outlet and the machine has a 20A plug.
Also, I want the outlet it self to be switchable, I prefer not to have a plug in module. (there is also very little space between the outlet and the machine)
Mon Oct 07, 2019 8:01 am
peszko offline
Re: Decent espresso
There is this: https://www.amazon.ca/Enerwave-Wireless-Resistant-Receptacle-REQUIRED/dp/B0170EFZ2G but its currently unavailable and not a GFI
Mon Oct 07, 2019 9:17 am
Re: Decent espresso
Is it a dedicated outlet? If so, you could swap the breaker for a GFI one. That would make finding a controllable outlet a little easier.
Mon Oct 07, 2019 9:53 am
peszko offline
Re: Decent espresso
Yes it is. Good idea, I haven't thought of that.. In the same vein, I guess I could put a z-wave switch in line in the electrical closet. This should make it even easier to find. Any suggestions welcome.
Users browsing this forum: No registered users and 20 guests
