All devices not responding
Mon Sep 23, 2019 8:26 am
fyellin offline
I got back from a week-long vacation, and suddenly none of my devices are responding. No software was updated. Nothing was changed.
When I check the logs, I don't see any indication that Alexa is making a connection to my device. I've even turned on debugging mode on the bridge. Giving a command to Alexa causes absolutely nothing to happen in the log.
I have rebooted the machine and restarted the Indigo server, just to make sure everything was clean.
I tried restarting the Alexa bridge, and I see in my log:
  Alexa-Hue Bridge                'Alexa Den' has 9  Alexa Devices published
   Alexa-Hue Bridge                Starting Hue Bridge 'Alexa Den' web server thread
   Alexa-Hue Bridge                Starting Hue Bridge 'Alexa Den' discovery thread as 'Auto Start Discovery' requested
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Alexa Den' started: Host: 10.6.90.8 Port: 8180
which is the right (internal) IP address and the right port. The Indigo server is on a static ip address, so that has changed.
Any idea how I go about debugging this?
Mon Sep 23, 2019 9:05 am
Re: All devices not responding
Read the other half-dozen threads in this forum about the same/similar problem.
