[Errno 64] Host is down [Errno 32] Broken pipe NO devices
Wed Sep 04, 2019 9:25 am
johnnyrt offline
Alexa never seems to discover any devices. I'm having an been trying to fix this for an embarrassing amount of time now.
Here's my log:
Sep 4, 2019 at 1:14:02 AM
Disabling plugin "Alexa-Hue Bridge 3.0.32"
Stopping plugin "Alexa-Hue Bridge 3.0.32" (pid 915)
Alexa-Hue Bridge Alexa-Hue Bridge shutdown requested
Alexa-Hue Bridge HTTP server stopping...
Alexa-Hue Bridge HTTP server stopped
Stopped plugin "Alexa-Hue Bridge 3.0.32"
Enabling plugin "Alexa-Hue Bridge 3.0.32"
Starting plugin "Alexa-Hue Bridge 3.0.32" (pid 1002)
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address is discovered as: '192.168.1.2'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, non-Echo Network Filter, Method Trace
Started plugin "Alexa-Hue Bridge 3.0.32"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'ALEX Test bridge' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'ALEX Test bridge' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'ALEX Test bridge' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'ALEX Test bridge' started: Host: 192.168.1.2 Port: 8178
Alexa-Hue Bridge 'ALEXA BRIDGE 1' has u3 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'ALEXA BRIDGE 1' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'ALEXA BRIDGE 1' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'ALEXA BRIDGE 1' started: Host: 192.168.1.2 Port: 8180
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to http://www.google.com successfully completed.
Sep 4, 2019 at 1:15:28 AM
Alexa-Hue Bridge Error 'ALEXA BRIDGE 1' Responder.run: socket error: [Errno 64] Host is down
Alexa-Hue Bridge Error 'ALEX Test bridge' Responder.run: socket error: [Errno 64] Host is down
Sep 4, 2019 at 1:23:43 AM
Alexa-Hue Bridge Error plugin does not define method checkRateLimit
Sep 4, 2019 at 1:33:11 AM
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'self.ahbDev.name'. Line '185' has error='[Errno 32] Broken pipe'
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'ALEXA BRIDGE 1'. Line '185' has error='[Errno 32] Broken pipe'
Does anyone have any ideas on what could be causing "Responder.run: socket error: [Errno 64] Host is down"
I have edited the hosts file,
Reinstalled the plugin.
Forgetting all devices on alexa.amazon.com
UpnP is on.
lsof -i :1900
Port forwarded set (just in case)
many many tests
My bridge logs are all turned on, however I don't think my echos are communicating in bound.
Thanks for any help.
Wed Sep 04, 2019 9:26 am
johnnyrt offline
Re: [Errno 64] Host is down [Errno 32] Broken pipe NO devic
Now I also have this:
Sep 4, 2019 at 3:08:23 AM
Sep 4, 2019 at 3:38:13 AM
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'ALEX Test bridge'. Line '185' has error='[Errno 32] Broken pipe'
Sep 4, 2019 at 4:13:18 AM
Sep 4, 2019 at 4:45:24 AM
Sep 4, 2019 at 5:50:19 AM
Fri Sep 06, 2019 2:46 am
autolog offline
What version Echo or Echo Dots are you running and what is their firmware version?
Can you also update to the latest version of the plugin 3.0.34 @ http://www.indigodomo.com/pluginstore/13/ and then try again and post the errors. :)
Sat Sep 07, 2019 11:28 am
johnnyrt offline
I have several, Echo 1st gen, a first gen dot, 1st gen echo show, an Echo Show 5 (small one) and 3 echo dots 2nd gen.
I'm running the newest version alexa hue bridge on a mac mini that had osx server insalled before ( I already edited the HOSTS file)
I'm not 100% sure my HOSTS file is correct, can someone let me know:
# Host Database
# localhost is used to configure the loopback interface
# when the system is booting.  Do not change this entry.
127.0.0.1   localhost
255.255.255.255   broadcasthost
::1             localhost
fe80::1%lo0   localhost
192.168.1.2 Thompson-Server
192.168.1.2 Thompson-Server.local
Sat Sep 07, 2019 11:32 am
johnnyrt offline
After reloading the plugin:
   Enabling plugin "Alexa-Hue Bridge 3.0.34"
   Starting plugin "Alexa-Hue Bridge 3.0.34" (pid 41612)
   Alexa-Hue Bridge                Plugin Host IP Address overridden and specified as: '192.168.1.2'
   Started plugin "Alexa-Hue Bridge 3.0.34"
   Alexa-Hue Bridge                Alexa-Hue Bridge network access check to www.google.com successfully completed.
Sep 7, 2019 at 10:31:37 AM
   Alexa-Hue Bridge Error          'ALEXA BRIDGE 1' Responder.run: socket error: [Errno 65] No route to host
Terminal sudo lsof -i :1900:
Thompson-Server:~ johnthompson$ sudo lsof -i :1900
COMMAND     PID         USER   FD   TYPE             DEVICE SIZE/OFF NODE NAME
IndigoPlu 20910 johnthompson   10u  IPv4 0x9f9e407f7df7d3ff      0t0  UDP *:ssdp
IndigoPlu 20910 johnthompson   13u  IPv4 0x9f9e407f7df7be3f      0t0  UDP *:ssdp
