- Code: Select all
Aug 22, 2019 at 8:00:00 AM
Schedule Inga lights off in morning
Schedule Sebastian Lights off in morning
Lutron RRA2/Caséta Girls' Room - Dimmer 116 - Overhead: Set brightness to 0 with fade 3
Lutron RRA2/Caséta Warning Error sending IP command, resetting connection: 'Plugin' object has no attribute 'connIP'
Lutron RRA2/Caséta Error Error in plugin execution ExecuteAction:
File "plugin.py", line 1619, in fadeDimmer
File "plugin.py", line 843, in _sendCommand
AttributeError: 'Plugin' object has no attribute 'connIP'
File "plugin.py", line 1509, in actionControlSpeedControl
Lutron RRA2/Caséta Girls - Inga Nightstand: Set brightness to 0 with fade 3
Lutron RRA2/Caséta Girls - Noemi Nightstand: Set brightness to 0 with fade 3
File "plugin.py", line 1314, in actionControlDimmerRelay
Then, when I restart the plugin I get this similar error message:
- Code: Select all
Reloading plugin "Lutron RRA2/Caséta 7.2.7"
Stopping plugin "Lutron RRA2/Caséta 7.2.7" (pid 57391)
Lutron RRA2/Caséta Shutting down Lutron
Lutron RRA2/Caséta Error Error in plugin execution shutdown:
File "plugin.py", line 160, in shutdown
Stopped plugin "Lutron RRA2/Caséta 7.2.7"
Is there any way to detect the failed connection and programmatically restart the plugin from within Indigo? Alternatively, any way for the plugin to detect the connection is hosed and reconnect?
