- 24 May 2019 at 12:03:39
Starting Indigo Server version 7.3.0 (Mac OS X 10.14.4)
Loading attachments
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7.3/Databases/CasaMilagro.indiDb"
Loading plugin "HomeKit Bridge 1.0.2"
Starting plugin "HomeKit Bridge 1.0.2" (pid 952)
HomeKit Bridge : Caching all HomeKit Bridge devices...
Started plugin "HomeKit Bridge 1.0.2"
HomeKit Bridge: Attempting to start 'Casa Milagro HomeKIt Server'
HomeKit Bridge: HomeKit Bridge is running the latest version, no update needed
HomeKit Bridge : HomeKit Bridge is loaded and ready to use
24 May 2019 at 12:04:10
Trigger: Start system Homebridge [=> This is where I start a separate Homebridge server instance outside of Indigo <=]
24 May 2019 at 12:05:05
HomeKit Bridge Error: HomeKit server 'Casa Milagro HomeKIt Server' could not be started, please check the service logs for more information,
now issuing a forced shutdown of the service to be safe.
If you continue to have problems starting this server use the Advanced Plugin Actions menu option to rebuild the Homebridge folder.
Instructions at https://github.com/Colorado4Wheeler/Hom ... dge-folder
HomeKit Bridge: Attempting to stop 'Casa Milagro HomeKIt Server'
HomeKit Bridge Error: Exception in hkfactory.send_refresh_to_homebridge line 177: HTTPConnectionPool(host='127.0.0.1', port=8445): Max retries exceeded with url: /devices/26e8fd7a8c2bb0241b4dab16e16ff364204ede07fd2e6554e05e8094db17f330 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x105ef6750>: Failed to establish a new connection: [Errno 61] Connection refused',))
CODE: r = requests.post(url, data=payload, headers=headers)
HomeKit Bridge Error: Exception in hkfactory.send_refresh_to_homebridge line 177: HTTPConnectionPool(host='127.0.0.1', port=8445): Max retries exceeded with url: /devices/26e8fd7a8c2bb0241b4dab16e16ff364204ede07fd2e6554e05e8094db17f330 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x105ef6ad0>: Failed to establish a new connection: [Errno 61] Connection refused',))
HomeKit Bridge Error: Exception in hkfactory.send_refresh_to_homebridge line 177: HTTPConnectionPool(host='127.0.0.1', port=8445): Max retries exceeded with url: /devices/26e8fd7a8c2bb0241b4dab16e16ff364204ede07fd2e6554e05e8094db17f330 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x105ef69d0>: Failed to establish a new connection: [Errno 61] Connection refused',))
HomeKit Bridge Error: Exception in hkfactory.send_refresh_to_homebridge line 177: HTTPConnectionPool(host='127.0.0.1', port=8445): Max retries exceeded with url: /devices/26e8fd7a8c2bb0241b4dab16e16ff364204ede07fd2e6554e05e8094db17f330 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x105ef6a90>: Failed to establish a new connection: [Errno 61] Connection refused',))
HomeKit Bridge: HomeKit server 'Casa Milagro HomeKIt Server' has been stopped
24 May 2019 at 12:05:54
24 May 2019 at 12:06:09 [=>At this point I manually restart the Plugin from Indigo <=]
HomeKit Bridge: Server 'Casa Milagro HomeKIt Server' has successfully started, you can use your HomeKit apps or Siri for this accessory [=> And, now it is running <=]
Any ideas?
