Python and Airfoil
Mon Oct 16, 2017 9:19 pm
jltnol offline
Python and Airfoil
So I've read the Wiki for AirFoil, and it has been a big help, since my Python ability is limited. I am curious about "chaining" commands... like the ability to connect 2 different speakers... or connect a speaker and set the volume....
While the following does work, I'm curious is there is a simpler way to do this, since most of the 2 commands are identical. I've tried a few things, re-arranging pieces, parts, deleting things that seemed redundant, including listing the execute actions part in (parentheses) back to back, then with a space, and then with a comma, but didn't get anywhere..
Is there a way to make multiple commands like this simpler?
airfoilPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.airfoilpro")
if airfoilPlugin.isEnabled():
        result = airfoilPlugin.executeAction("connect", deviceId= 1346544642, waitUntilDone=True)  # ID of Speaker device
    except Exception, e:
        print "Exception occurred: %s" % unicode(e)
        result = airfoilPlugin.executeAction('setVolume', deviceId=1346544642, props={'volume': 52}, waitUntilDone=True)  # ID of Speaker device
Tue Oct 17, 2017 4:16 am
Re: Python and Airfoil
        print "Exception occurred  on connect: %s" % unicode(e)
        print "Exception occurred on setVolume: %s" % unicode(e)
Tue Oct 17, 2017 6:49 am
jltnol offline
Thanks ever so much
this is one of the combos that I tried, but obviously didn't have something exactly right.
Tue Oct 17, 2017 6:52 am
Notice I added text to identify which exception was caught. You probably want to change the print statements to indigo log statements.
Tue Oct 17, 2017 9:53 am
You could further simplify by putting all calls in the same try block:
Exceptions here are pretty unlikely, so my guess is that if the first one works the second one will almost always work, and any exception you get will very likely be because of some systemic problem and you're probably seeing a LOT of other problems as well.
Tue Aug 06, 2019 5:22 pm
mgolden50 offline
Hi Jay,
I've been trying to use your example below for how to set speaker volumes and it doesn't change the volume levels shown on the Airfoil UI.
airfoilPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.Airfoil")
airfoilPlugin.executeAction("setVolume", props={'volume':"99", 'speakerIds':["127530933","1824678982"]})
Also can you provide a Python example for getting a speaker volume setting into a local Python variable?
Mike
Tue Aug 06, 2019 5:58 pm
You have the volume as a string rather than a number.
    airfoilPlugin.executeAction("setVolume", props={'volume':99, 'speakerIds':["127530933","1824678982"]})
I have no idea if that syntax is correct for multiple speakers.
Wed Aug 07, 2019 8:27 am
FlyingDiver is correct - volume should be a number.
Examine the Set Volume action script example:
        result = airfoilPlugin.executeAction('setVolume', deviceId=135305663, props={'volume': 50}, waitUntilDone=True)  # ID of Speaker device
The action targets a single speaker, so you specify the speaker device using the deviceId param. To set the volume on multiple speakers, you need one executeAction call per speaker.
Sat Aug 17, 2019 10:57 am
jltnol offline
Belated THANKS!
Wed Jul 06, 2022 6:25 pm
Alain offline
Since the recent update to Python, I am not getting an error when I set the Airfoil volumes from variables.
The error seems to be associated with the line:
exception Exception, e:
and the error I get is: "multiple exception types must be parenthesized".
Can anyone help?
Alain
Wed Jul 06, 2022 7:56 pm
Are you using the old Airfoil plugin or the Airfoil Pro plugin included with Indigo?
Wed Jul 06, 2022 7:59 pm
Alain offline
I believe the one that comes with Indigo. I haven’t done anything deliberate to stay with an old plug-in.
Thu Jul 07, 2022 5:58 am
What's the actual name of the plugin in the plugin list?
Thu Jul 07, 2022 6:02 am
Alain offline
In the Plugin list, it says Airfoil Pro, and in its pulldown menu it says "About Airfoil Pro v2022.1.0"
Thu Jul 07, 2022 6:03 am
Can you copy the complete section of the log with the error? It should have a code line number.
