Z-Wave keypad
Wed Jul 17, 2019 2:15 pm
rgspb offline
Z-Wave keypad
Is there a Z-Wave keypad that is a good replacement for the Insteon Keypadlinc?
Wed Jul 17, 2019 2:43 pm
Re: Z-Wave keypad
Wed Jul 17, 2019 2:49 pm
rgspb offline
Re: Z-Wave keypad
Thanks, I'm going to try one of the WallMotes!
Wed Jul 17, 2019 4:02 pm
Dual offline
Re: Z-Wave keypad
Please let us know if you can control the indicator lights separately.
Fri Jul 19, 2019 3:47 pm
rgspb offline
Re: Z-Wave keypad
Well the little remote works great! One annoying problem is there's no way to turn the thing off. I printed out some labels for it and had to disable it in Indigo and it just kept beeping at me as I was applying the labels. It actually looks bad with labels on it but it needs to be indicated somehow what button does what. As far as controlling the indicator lights separately I'm not real sure what that means. There's only one light and it forms a cross in the middle of the touch panels. There is an option in the setup for "Touch LED Color" but it is not enabled. I guess that's a programming thing with Indigo?
Fri Jul 19, 2019 3:54 pm
Re: Z-Wave keypad
The Touch LED Color config UI should be enabled, but if during sync Indigo isn't able to read out the parameter value it disables it. Try re-syncing it in Indigo again to see if it enables it. If it doesn't then copy/paste the Event Log results of the sync into a reply for me.
Fri Jul 19, 2019 6:20 pm
rgspb offline
Re: Z-Wave keypad
That didn't do it. Here's the log for you:
Z-Wave Syncing - started for "WallMote1"
Z-Wave Syncing - retrieved module neighbors list: 2, 7, 12, 16, 21, 28, 37, 38, 40, 41, 42, 43, 44, 45, 47, 48
Z-Wave Syncing - assigning return route to "063 - WallMote1"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, WallMote Quad (ZW130) - 01020082
Z-Wave Syncing - retrieved protocol version 4.62, app version 2.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 20v1 84v2 85v1 86v1 8Ev1 59v1 5Av1 5Bv1 5Ev1 60v4 70v1 71v1 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "063 - WallMote1" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved multi-endpoint types: 1:(18 : 01), 2:(18 : 01), 3:(18 : 01), 4:(18 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E], 2:[5E 85 59 8E], 3:[5E 85 59 8E], 4:[5E 85 59 8E]
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Syncing - retrieved group 7 associations: []
Z-Wave Syncing - retrieved group 8 associations: []
Z-Wave Syncing - retrieved group 9 associations: []
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - retrieved parameter 4 "Scene type" is 1
Z-Wave Syncing - retrieved parameter 1 "Beep on touch" is true
Z-Wave Syncing - retrieved parameter 2 "Vibrate on touch" is true
Z-Wave Syncing - retrieved parameter 3 "Allow touch-drag up/down to brighten/dim direct associations" is false
Jul 19, 2019 at 8:18:39 PM
Z-Wave Syncing - failed to retrieve parameter 5 "Touch LED color" (skipping)
Z-Wave Syncing - retrieved battery level of 56%
Z-Wave Syncing - complete
Fri Jul 19, 2019 6:24 pm
Dual offline
Re: Z-Wave keypad
Sorry. My mistake. I was thing you were trying one of the Leviton devices from the other thread.
Sat Jul 20, 2019 3:34 am
agame offline
Re: Z-Wave keypad
I have one of the remotec devices and it works well.
But for a high-end result, the reality is its not that pretty (or at best won't match the rest of a house's switchgear).
My work-around to date has been to commandeer the switch-2 input of Fibaro dimmers, and even to use both S1 and S2 inputs where unavoidable without a physically switched light load (it needs a bypass as dummy load however). With scenes multiple actions an be attached to a single switch however in the objective is general usability in my experience this usually is not going to user friendly.
The S2 switches are often effectively 'free' but of course are randomly distributed across a house, but using dedicated dimmers is a very expensive (and high voltage!) approach. I'm currently contemplating how to implement a scenario such as you've described (several switches in a panel for scenes, remote control of outdoor lights, master switches etc). I'm contemplating either the 8 channel relay (for which there's a great plugin); or Global Cache flex device. The Flex integration with Indigo is fast in response (using UDP), but has only 4 inputs whereas the 8-channel relay needs to be polled every few seconds (but with 8 I/O pairs is amazingly cheap!).
