- Code: Select all
Cynical SecuritySpy Error SecuritySpy ServerMiniMac unavailable: unrecognized server version - BBVS/5.0
Cynical SecuritySpy Error SecuritySpy Hikvision Back Gate unavailable: host device xxx is unavailable
Cynical SecuritySpy Error SecuritySpy Hikvision Driveway unavailable: host device xxx is unavailable
Cynical SecuritySpy Error SecuritySpy Hikvision Front Door unavailable: host device xxx is unavailable
Cynical SecuritySpy Error in runConcurrentThread: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 58, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 68, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/cyin/asynplugin.py", line 64, in runConcurrentThread
self.run()
File ".../Server Plugin/asyn/inject.py", line 61, in run
asyn.Controller.run(self)
File ".../Server Plugin/asyn/controller.py", line 105, in run
item._can_read()
File ".../Server Plugin/asyn/selectable.py", line 229, in _can_read
self._null_read()
File ".../Server Plugin/asyn/selectable.py", line 97, in _null_read
self.callout(END)
File ".../Server Plugin/asyn/core.py", line 152, in callout
results = [cb(ctx, *args) for cb in list(self._callbacks)] # latch callback list
File ".../Server Plugin/asyn/http.py", line 304, in incoming
return self.callout('body', self.body)
File ".../Server Plugin/spy/core.py", line 120, in reply
self._configure(arg)
File ".../Server Plugin/spy/core.py", line 171, in _configure
camera = Camera(elem, self)
File ".../Server Plugin/spy/core.py", line 283, in __init__
if self.spy.webversion >= 4:
AttributeError: 'SecuritySpy' object has no attribute 'webversion'
Cynical SecuritySpy Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
