Python Coding Help - Finding BeautifulSoup
Tue Jul 02, 2019 8:03 am
stanleykrasnow offline
I am trying to use Indigo to schedule a Python script which contains the use of BeautifulSoup to scrape a web site. I use Anaconda / Spyder (2.7) to write and maintain the Python script. The Python script works in the Spyder environment, but fails when running in Indigo.
Under Indigo the environment cannot find BeautifulSoup " embedded script, line 57, at top level ImportError: No module named bs4", despite trying to include it using the Python invocation: sys.path.append ("/anaconda2/lib/python2.7/site-packages"). Can someone please help be get to BeautifulSoup? Line 57 is: from bs4 import BeautifulSoup # to parse the HTML on a web page
Thank you,
Stan Krasnow
My python code is:
#!/usr/bin/env python2
# -*- coding: utf-8 -*-
Created on Sat Jun 29 14:46:27 2019
@author: XXX
#  Scrape selected data from CeleriusVI_URL
#  Two key websites:
#  https://teamtreehouse.com/community/help-with-pythons-beautiful-soup-html-question
#  https://martechwithme.com/introduction-to-web-scraping-with-python-extracting-data-from-a-page/
import sys
# sys.path.append ("/Library/Python/2.7/site-packages")
from indigo_attachments import log_or_print as lop
lop ("Starting Celerius VI Scraping")
from random import randint
USER_AGENTS = [
    ('Mozilla/5.0 (X11; Linux x86_64) '
     'AppleWebKit/537.36 (KHTML, like Gecko) '
     'Chrome/57.0.2987.110 '
     'Safari/537.36'),  # chrome
     'Chrome/61.0.3163.79 '
    ('Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:55.0) '
     'Gecko/20100101 '
     'Firefox/55.0'),  # firefox
     'Chrome/61.0.3163.91 '
     'Chrome/62.0.3202.89 '
     'Chrome/63.0.3239.108 '
random_agent_count = randint(0, (len(USER_AGENTS)-1))
import requests                 #  to fetch a web page
from datetime import datetime   #  to get today's date for email
#  anaconda2⁩ ▸ ⁨pkgs⁩ ▸ ⁨beautifulsoup4-4.7.1-py27_1⁩ ▸ ⁨lib⁩ ▸ ⁨python2.7⁩ ▸ ⁨site-packages⁩  done below
#  sys.path.append ("/anaconda2/pkgs/beautifulsoup4-4.7.1-py27_1/lib/python2.7/site-packages")
#  anaconda2⁩ ▸ ⁨lib⁩ ▸ ⁨python2.7⁩ ▸ ⁨site-packages⁩   done below
#  sys.path.append ("/anaconda2/lib/python2.7/site-packages")
import smtplib                  #  to send an email
headers = {'User-Agent': USER_AGENTS[random_agent_count]}  #  try to avoid scraping defences
CeleriusVI_URL = "https://www.bloomberg.com/quote/ACELVIP:LX"
request = requests.get(CeleriusVI_URL, headers=headers)    # First "fetch" the URL using requests
content = request.content                                  # Then retrieve the content
# Give the web content to BeautifulSoup
soup = BeautifulSoup(content, 'lxml')
#  Get the as of date
#         <span class="fieldLabel__9f45bef7"><span>Total Assets (M EUR) (On 06/28/2019)</span></span>
#         <span>Total Assets (M EUR) (On 06/28/2019)</span>
find_CeleriusVI_as_of_date = soup.find_all("span", class_="fieldLabel__9f45bef7", attrs= "Total Assets (M EUR)")
CeleriusVI_HTML_index = 6         #  trial and error index of SPANs
find_text = find_CeleriusVI_as_of_date[CeleriusVI_HTML_index].text
#  lop (str(find_CeleriusVI_as_of_date) + "XXX")
CeleriusVI_as_of_date = "o" + find_text[6:]                #  clean-up return from BS; add lower case o in the word On
CeleriusVI_as_of_date = CeleriusVI_as_of_date[:-1]         #  clean-up return from BS;
#  Get the Celerius Current Asset Value
#  <span class="fieldValue__2d582aa7">82.348</span>
find_CeleriusVI_Value = soup.find_all("span", class_ = "fieldValue__2d582aa7")
CeleriusVI_HTML_index = 7          #  trial and error index of SPANs
CeleriusVI_Value = find_CeleriusVI_Value[CeleriusVI_HTML_index].text
euro = u"€"                                                 #  unicode character for printing
lop (CeleriusVI_as_of_date + " the value of Celerius VI is " + euro + CeleriusVI_Value + "m")
lop ("End of Celerius VI Scraping")
Tue Jul 02, 2019 9:17 am
FlyingDiver online
Re: Python Coding Help - Finding BeautifulSoup
Do "sudo pip install bs4" in Terminal so that the library gets installed where Python expects it to be.
Also, please use CODE tags when posting Python code.
Tue Jul 02, 2019 9:41 am
You seem to have multiple copies of Python installed, which is known to cause path issues with Indigo. Specifically, you're attempting to point to /anaconda2/lib/python2.7/site-packages which is not a standard python path for the built-in python installation on macOS (and python2 is not the standard name of the python 2.7 executable in macOS).
Tue Jul 02, 2019 9:42 am
FlyingDiver online
If all you need to do is run the script on a schedule, why not use cron? Much simpler than trying to make this work in Indigo.
Tue Jul 02, 2019 9:47 am
That's definitely a matter of opinion! :lol: :D
Tue Jul 02, 2019 9:48 am
FlyingDiver online
Well, the scheduling part is harder, but making it work in the standard Python environment is yet to be seen...
Tue Jul 02, 2019 10:14 am
Actually, it just occurred to me that if he changed the script to executable (chmod +x name_of_script.py) then he could execute it from the Run Shell Script action as-is (it would be run in his specified python2 install). He will have to specify the full path to his python2 executable in the shebang line rather than using the env command since it's not likely that his python2 install is in the default path:
#!/full/path/to/custom/python2
I still believe however that sorting out the multiple python install issue is the way to avoid this and other issues in the future.
