cannot select door from august home plugin
Fri Jun 21, 2019 8:08 pm
farberm offline
Karl:
I can get one trigger to work just fine and define plugin as the unifi plugin for sensors (phones present).
I tried to create a second trigger using the unifi presence sensors and a door lock (august plugin) It never canlocate the door lock that I have defined?
Also if I try to create a second trigger for all devices away based only on the unifi sensors it will not let me enable the trigger?
Sat Jun 22, 2019 6:40 am
Could you post more details on your configs and setup?
Ie states of the devices used for the trigger
Sat Jun 22, 2019 11:10 am
farberm offline
Re: cannot select door from august home plugin
I think I got it to work. I had to go in and define not just the plugin but also define the door
