Since upgrading to latest plugin release (and skipping an unknown number of intermediate releases), all my RPIs are constantly cycling. As in:
up
expired
IPconnection and BLE down
up
expired
Additionally, no iBeacons are ever detected, even if I set to accept all new iBeacons. I haven't seen anything suspicious in the plugin logfile.
When I ssh to the RPI, I can see that almost all the files have been recently updated:
- Code: Select all
$ ls -l ~/pibeacon
total 2124
-rwxrwxrwx 1 pi pi 1938 Jun 17 19:50 actions.py
-rwxrwxrwx 1 pi pi 19925 Jun 17 19:50 amg88xx.py
-rwxrwxrwx 1 pi pi 64587 Jun 17 19:50 apds9960.py
-rwxrwxrwx 1 pi pi 18156 Jun 17 19:50 as3935.py
-rwxrwxrwx 1 pi pi 22403 Jun 17 19:50 as726x.py
-rw-rw-rw- 1 pi pi 3615 Jun 17 18:59 beacon_ExistingHistory
-rwxrwxrwx 1 pi pi 41464 Jun 17 19:50 beaconloop.py
-rw-rw-rw- 1 pi pi 2036 Jun 17 20:26 beacon_parameters
-rwxrwxrwx 1 pi pi 11391 Jun 17 19:50 BLEconnect.py
-rwxrwxrwx 1 pi pi 19329 Jun 17 19:50 BLEsensor.py
-rwxrwxrwx 1 pi pi 35107 Jun 17 19:50 bme680.py
-rwxrwxrwx 1 pi pi 31084 Jun 17 19:50 bno055.py
-rwxrwxrwx 1 pi pi 4321 Jun 17 19:50 callbeacon.py
-rwxrwxrwx 1 pi pi 19863 Jun 17 19:50 ccs811.py
-rwxrwxrwx 1 pi pi 804 Feb 25 19:03 checkLogfile.py
-rwxrwxrwx 1 pi pi 1096 Jun 17 19:50 convert.py
-rwxrwxrwx 1 pi pi 1453 Jun 17 19:50 copyToTemp.py
-rwxrwxrwx 1 pi pi 8184 Jun 17 19:50 DHT.py
-rwxrwxrwx 1 pi pi 8149 Jun 17 19:50 displayDistance.py
drwxrwxrwx 2 pi pi 4096 Jun 7 2017 displayfiles
-rwxrwxrwx 1 pi pi 75914 Jun 17 19:50 display.py
-rwxrwxrwx 1 pi pi 210 Jun 17 20:29 doGPIOatStartup.py
<<--SNIP-->>
But there are definitely errors in the RPI log:
- Code: Select all
$ tail -F /var/log/piBeacon.log
20190617-20:29:12 INPUTgpio L:-1= starting setup sensors
20190617-20:29:12 master L:-1= Master adhocWifi is:-1 ; G.wifiType is:normal
20190617-20:29:12 Wire18B20 L:-1= error in Line 513 has error=global name 'wifiIP' is not defined
20190617-20:29:12 master L:-1= error in Line 513 has error=global name 'wifiIP' is not defined
20190617-20:29:22 master L:-1= error in Line 513 has error=global name 'wifiIP' is not defined
20190617-20:29:22 master L:-1= IP find:::: Indigo IP#>>172.23.2.10<<; wifiIP >><<; eth0IP: >><<; hostnameIP >>['172.23.2.60']<<; ipAddressRead >>172.23.2.60<<; requested Config:{'wlan0': {'on': 'dontChange', 'useIP': 'use'}, 'eth0': {'on': 'dontChange', 'useIP': 'use'}}
20190617-20:29:23 master L:-1= testPing input>>172.23.2.1<< indigoIP>>172.23.2.10<<
20190617-20:29:23 master L:-1= DNS server reachable at:172.23.2.1
20190617-20:29:23 master L:-1= testPing input>><< indigoIP>>172.23.2.10<<
FWIW, I'm seeing the same behavior in 4 different ZeroW's connected by wifi (one of which also has 1-wire sensors). Everything worked as expected for a year or more before yesterday.
I'd appreciate any help to figure this out.
Thanks.
