Ability to manage multiple Lutron Caseta Hubs
Wed Jun 19, 2019 8:40 am
ryandenver offline
Greetings
I am in the process of removing ~70 Insteon DIN Dimmers from my home as they aren't working properly and looking to replace them with Caseta dimmers mounted in the same location in the basement mechanical room. I already plan to have Indigo setup to serve as the automation platform across various product families and wanted to know if the Indigo/Lutron plug-in can control multiple Lutron PRO Hubs (most likely 2) as I know the HomeSeeker platform can do this.
Thanks for any insights.
Wed Jun 19, 2019 9:10 am
Re: Ability to manage multiple Lutron Caseta Hubs
The current plugin does not support multiple hubs, but I have an open enhancement request to do so: https://github.com/FlyingDiver/Indigo-r ... /issues/32
If you decide to go down that road, I can move that issue up the priority list. It's not a huge amount of work, but will require a fair amount of testing.
On the other hand, I would recommend you look into using RadioRa 2 or RRA2 Select rather than Caseta for that many units. You'll get a lot more functionality with RRa2. You can get the Essentials programming software (Windows only) just by doing their on-line training. Probably six hours total time. For quotes on RRa2 hardware, I recommend you contact Paul Willemsen <paul@hankselectric.net>.
Wed Jun 19, 2019 10:25 am
ryandenver offline
Thank you for the quick reply and offer to move this up in the queue. I will likely make a decision this week or next as our house is nearing completion. I've looked at RRa2 and RRa2Select, but from a price point for just dimming, Caseta hits our needed functionality since I'll be using Indigo as an automation layer between all of our different brand platforms (light, sound, audio, HVAC, shades, etc).
If I were to move forward and you were able to move the enhancement forward, what do you foresee a possible delivery timeline being? Just trying to plan around our move in date.
Thanks again..
Wed Jun 19, 2019 10:31 am
Depends on when I get over this case of bronchitis I'm fighting. Less than a week to a beta-level version, I would guess. When's your move-in date?
Wed Jun 19, 2019 10:34 am
ryandenver offline
Looking at an Aug 1 move in date. Had planned to use Insteon as that had worked in our last home, but the ~70 DIN Dimmers we installed showing mixed results in the new home, so this is a last minute audible with the electrician. :|
Fri Jun 21, 2019 6:44 pm
Well, I've got a version of the plugin on my development system that should work with multiple systems. Biggest problem is that I have no way to test it completely. I don't even have a good way to test it with serial-connected RRa2 systems.
I'll be putting it out for beta testing soon.
Thu Jun 27, 2019 5:38 am
ryandenver offline
Appreciate the updates and the work on this. I won't have my system operational for a few more weeks, but look forward to the results.
Thu Oct 08, 2020 10:51 am
docbjr offline
Can the plugin handle both Radio Ra 2 and Caseta hubs at the same time?
thx
Thu Oct 08, 2020 11:03 am
thx
Yes. You create one gateway device for the RRa2 repeater, and a second one for the Caseta hub.
