Event Log Flooded with NOAA
Mon May 06, 2019 12:42 pm
ckeyes888 offline
Hoping to find out where these event logs are coming from. They just started the other day. I've disabled all NOAA plugins
and removed the old background task I had been using. I'm using FW for virtually everything now.
Any idea what they could be?
2019-05-06 12:14:21.215   Weather NOAA   Variable "Weather_Pressure" is not present in the NOAA data file.
2019-05-06 12:14:21.217   Weather NOAA   Variable "Weather_Pressure_mb" is not present in the NOAA data file.
2019-05-06 12:14:21.701   Weather NOAA   Variable "Weather_Pressure" is not present in the NOAA data file.
2019-05-06 12:14:21.702   Weather NOAA   Variable "Weather_Pressure" is not present in the NOAA data file.
2019-05-06 12:14:21.703   Weather NOAA   Variable "Weather_Pressure_mb" is not present in the NOAA data file.
2019-05-06 12:14:21.705   Weather NOAA   Variable "Weather_Pressure_mb" is not present in the NOAA data file.
2019-05-06 12:14:22.263   Weather NOAA   Variable "Weather_Pressure" is not present in the NOAA data file.
2019-05-06 12:14:22.265   Weather NOAA   Variable "Weather_Pressure_mb" is not present in the NOAA data file.
2019-05-06 12:14:22.816   Weather NOAA   Variable "Weather_Pressure" is not present in the
Carl
Mon May 06, 2019 2:12 pm
jalves offline
Re: Event Log Flooded with NOAA
Go to your Devices window and click on the "protocol" column to sort it alphabetically, then scan down to find the device that uses "NOAA Weather Plus". Disable/delete that and you should be OK.
Jeff
Mon May 06, 2019 4:28 pm
That's not coming from the NOAA Weather plugin but rather from the very old Weather NOAA sync.scpt AppleScript file. You apparently missed a startup trigger (or something else) that's running that script.
Mon May 06, 2019 7:56 pm
ckeyes888 offline
I’m sure you’re right but I can’t find one that is active.
Carl
Tue May 07, 2019 9:20 am
ckeyes888 offline
I did have the script in the old Indigo 7 attachments folder. I removed it and all is well.
Not sure why that folder would be active though.
Carl
Tue May 07, 2019 9:43 am
Indigo doesn't automatically start up scripts in any folder so it's something in your config that was starting it up. My guess is the next time you upgrade Indigo it'll start doing it again until you figure out what in your system is running it.
Tue May 07, 2019 3:29 pm
ckeyes888 offline
I’d thought that was what the Attachments folder was for.
Carl
Tue May 07, 2019 5:37 pm
No. The Attachments folder makes AppleScript handlers contained in those files available to other AppleScripts, but it doesn't actually execute them.
Tue May 07, 2019 7:08 pm
ckeyes888 offline
Got it. Thanks.
Carl
Sun May 26, 2019 11:13 am
ckeyes888 offline
I removed all the NOAA related scripts, triggers, actions etc. I could find and am still getting a flood of these in my log.
2019-05-26 10:49:35.847 Weather NOAA ParseXML:System Events got an error: Some data was the wrong type.(-1703)
I'm not using anything related to NOAA anymore, old plugins are inactive.
Really appreciate any ideas where the error might be coming from.
Carl
Sun May 26, 2019 3:38 pm
FlyingDiver online
Time to go digging in the Indigo database. It's XML, so you can search it in a text editor. Look for the string "Weather NOAA".
Sun May 26, 2019 4:01 pm
+1. You've missed a script somewhere...
Just duplicate your DB before opening it with a text editor to avoid issues.
Mon May 27, 2019 4:15 pm
ckeyes888 offline
Nothing shows on a search of Weather NOAA. Lot’s of returns for NOAA but I have no idea what they may be.
I’ve never edited the database file before...not sure how to go about it.
Carl
Tue May 28, 2019 9:15 am
Email us your db file and a log file that contains that shows the error (support@indigodomo.com) and reference this thread.
Tue May 28, 2019 11:20 am
ckeyes888 offline
Thanks Jay. No doubt you have more important things to do.
Since deleting all references, scripts etc. to NOAA
and restarting Indigo I haven’t seen the errors yet.
If they return I’ll send the db and log along.
Carl
