Becomes more than
Fri May 24, 2019 2:55 pm
Becomes more than
Guys,
Can you remind me how/why my device states in triggers are only allowing Equal/Not Equal, rather than Greater/Less than?
Initially the device state was stored as str(value), but i've changed it to int(value) and checked in the scripting shell that indigo.devices[123].states['power'] is now an int.
What else do I need to fix?
PEter
Fri May 24, 2019 3:07 pm
Re: Becomes more than
What is the actual state definition in Devices.xml?
Fri May 24, 2019 3:18 pm
Erm, textfield I think?
Fri May 24, 2019 3:22 pm
Nope, you’re spot on.
It’s string and needs to be number.
I knew I’d had this <strike>argument</strike> <strike>discussion</strike> problem before, but couldn’t remember why!
Sat May 25, 2019 9:23 am
Right now types aren't enforced as much as "hinted", particularly WRT device states. This is something we will make even more pervasive as time goes by so that the UI can be more reactive.
