Search link tables for Insteon ID
Thu Apr 18, 2019 1:01 pm
Brandt offline
I had linked Insteon's Hub Pro to a handful of devices when I was curious about their HomeKit offerings. Unfortunately it never worked out, so I would like to make sure I remove the Insteon ID of the Hub Pro from all my devices.
Is there a way to search the link tables of all devices for a particular Insteon ID? I know holding down the Option key while managing links allows one to remove unknown links.
thanks in advance...
Indigo 7 w/ Dual-Band 2413U PLM
macOS High Sierra 10.13.x
2011 iMac 3.4 GHz Intel Core i7
Fri Apr 26, 2019 10:17 am
Re: Search link tables for Insteon ID
Create an Action Group with an action that executes this embedded python script:
for dev in indigo.devices:
   links = indigo.rawServerRequest("GetLinksForDevice", {"Name":dev.name})
   indigo.server.log("responder links in \"%s\":" % (dev.name))
   for link in links.get("ResponderList", []):
      indigo.server.log("%s" % (link["AddressStrUI"]))
   indigo.server.log("")
   indigo.server.log("controller links in \"%s\":" % (dev.name))
   for link in links.get("ControllerList", []):
Fri Apr 26, 2019 10:23 am
Brandt offline
What does this error mean:
   Script Error                    embedded script: 'key AddressStrUI not found in dict'
   Script Error                    Exception Traceback (most recent call shown last):
     embedded script, line 5, at top level
KeyError: 'key AddressStrUI not found in dict'
Fri Apr 26, 2019 10:26 am
I'm not sure why that key doesn't exist, but just try this instead:
      indigo.server.log("%s" % (link.get("AddressStrUI", "--")))
Fri Apr 26, 2019 10:34 am
Brandt offline
Thanks Matt,
Is there a way to search for just the unknown back links?
Fri Apr 26, 2019 10:59 am
Not easily. I figured you had the Insteon address of the old controller and you could just search on that in the results?
Fri Apr 26, 2019 11:00 am
Brandt offline
I do, thank you!
