Hi all,
I am not getting what this plugin is for.
Is it to control Indigo Devices using Alexa?
I have a Sonos Beam with Alexa integrated; would it be possible to use it and control Indigo devices via Alexa?
Marco
autolog wrote:To add to Simon's good overview; you also need to have an Amazon Echo (gen 1) or an Amazon echo Dot (gen 1 or gen 2) for the plugin to work. As long as you have at least one of the aforementioned devices in your Alexa network then later generations will also likely work as the commands get funnelled through the earlier gen models to Indigo.
ckeyes888 wrote:Just for the record you can use virtually any phrase you like, e.g. Open/Close, by setting up Alexa routines.
I use a number of them, “Alexa, reset the router.”, “Alexa, open the garage door” etc.
Carl
MarcoGT wrote:... But I think they are not available on the market, are they?
rgspb wrote:Are you setting up these routines in the Alexa App?
