You’re welcome Jay.
WebServer request to execute "_preview_control page" control #6 from 192.168.1.253
Sent INSTEON "PowerLinc Interface" dim by 3 (scene 19 - FR Lights slow ramp)
Error should never send dim direct command
Sent INSTEON " group Family Room Torchiere Lamp North" dim by 0 (scene 19 cleanup)
Sent INSTEON " group Family Room Torchiere Lamp South" dim by 0 (scene 19 cleanup)
Error device "Weather Station" state key dayRain_- not defined (ignoring update request)
Error device "Weather Station" state key monthEvapotranspiration_- not defined (ignoring update request)
Error device "Weather Station" state key stormRain_- not defined (ignoring update request)
Error device "Weather Station" state key last24HourRain_- not defined (ignoring update request)
Error device "Weather Station" state key dayEvapotranspiration_- not defined (ignoring update request)
Error device "Weather Station" state key rainRate_- not defined (ignoring update request)
Error device "Weather Station" state key windSpeed_f/s not defined (ignoring update request)
Error device "Weather Station" state key twoMinuteAverageWindSpeed_f/s not defined (ignoring update request)
Error device "Weather Station" state key yearRain_- not defined (ignoring update request)
Error device "Weather Station" state key tenMinuteWindGust_f/s not defined (ignoring update request)
Error device "Weather Station" state key tenMinuteAverageWindSpeed_f/s not defined (ignoring update request)
Error device "Weather Station" state key yearEvapotranspiration_- not defined (ignoring update request)
Error device "Weather Station" state key monthRain_- not defined (ignoring update request)
t-star wrote:Upgraded today to 7.3. getting the following error with the HomeSeer 200+ switches. Setting LED mode into either normal or custom mode. Get the same error.
dduff617 wrote:I'm testing the new scene brightening, dimming commands. ... The commands seem to work, but each time I execute one of the commands, I see some errors in the logs.
howartp wrote:Re sorting the column, that’s one for Matt/Jay to look at. As plugin devs we can set two values for state, one for calculations and one for visual - say “10” and “10° C” - I don’t know if they’re using the uiValue to display the sync message, or some other way.
jay (support) wrote:howartp wrote:Re sorting the column, that’s one for Matt/Jay to look at. As plugin devs we can set two values for state, one for calculations and one for visual - say “10” and “10° C” - I don’t know if they’re using the uiValue to display the sync message, or some other way.
This has been discussed many times over the years. We may someday revisit how that sorting is done, but suffice it to say that there are opinions on how that sorting should work and not a good general consensus when they don't work as you might expect...
