Weathersnoop errors after upgrade to 4.1.8
Sat Apr 13, 2019 8:06 pm
roquej offline
After the upgrade, getting the following errors in the log:
Error device "Weather-VantageVue" state key dayRain_- not defined (ignoring update request)
Error device "Weather-VantageVue" state key monthEvapotranspiration_- not defined (ignoring update request)
Error device "Weather-VantageVue" state key dayEvapotranspiration_- not defined (ignoring update request)
Error device "Weather-VantageVue" state key rainRate_- not defined (ignoring update request)
Error device "Weather-VantageVue" state key windSpeed_f/s not defined (ignoring update request)
Error device "Weather-VantageVue" state key twoMinuteAverageWindSpeed_f/s not defined (ignoring update request)
Error device "Weather-VantageVue" state key yearRain_- not defined (ignoring update request)
Error device "Weather-VantageVue" state key tenMinuteWindGust_f/s not defined (ignoring update request)
Error device "Weather-VantageVue" state key tenMinuteAverageWindSpeed_f/s not defined (ignoring update request)
Error device "Weather-VantageVue" state key yearEvapotranspiration_- not defined (ignoring update request)
Error device "Weather-VantageVue" state key monthRain_- not defined (ignoring update request)
Plugin version is 3.0.1
Any suggestions?
JP
Wed Apr 17, 2019 3:03 pm
ticotice offline
Re: Weathersnoop errors after upgrade to 4.1.8
I'm having exactly the same problem. :( I've reached out to Boisy (the WeatherSnoop author) but haven't heard anything yet. Hope it is a simple fix.
Sat Apr 20, 2019 1:52 pm
GRWilde offline
I am getting continual similar errors as follows. I had to disable the plugin. I also contacted Boisy Pitre and filed a bug report, but have not yet heard back. Basically the plugin is unusable until it is fixed.
Error device "WeatherSnoop" state key dayRain_- not defined (ignoring update request)
Error device "WeatherSnoop" state key monthEvapotranspiration_- not defined (ignoring update request)
Error device "WeatherSnoop" state key dayEvapotranspiration_- not defined (ignoring update request)
Error device "WeatherSnoop" state key rainRate_- not defined (ignoring update request)
Error device "WeatherSnoop" state key windSpeed_f/s not defined (ignoring update request)
Error device "WeatherSnoop" state key twoMinuteAverageWindSpeed_f/s not defined (ignoring update request)
Error device "WeatherSnoop" state key yearRain_- not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteWindGust_f/s not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteAverageWindSpeed_f/s not defined (ignoring update request)
Error device "WeatherSnoop" state key yearEvapotranspiration_- not defined (ignoring update request)
Error device "WeatherSnoop" state key monthRain_- not defined (ignoring update request)
George Wilde
Sat Apr 20, 2019 4:44 pm
Have you tried deleting the device in Indigo then recreating it?
Sat Apr 20, 2019 9:30 pm
GRWilde offline
I did try deleting the device in Indigo and recreating it. Got the following errors:
WeatherSnoop Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1179, in deviceUpdated
File "plugin.py", line 217, in deviceStartComm
StandardError: LowLevelBadParameterError -- illegal character in XML tag name or value
And when setting up
Error (client) _setCurrentPluginDeviceType() caught exception: LowLevelBadParameterError -- illegal character in XML tag name or value
Error (client) runDialogForDevice() caught exception: LowLevelBadParameterError -- illegal character in XML tag name or value
Error device "WeatherSnoop" state key indoorTemperature_F not defined
The plugin provides no status or device information from WeatherSnoop.
George Wilde
Sun Apr 21, 2019 12:06 pm
Yeah, unfortunately that looks like a bug in WeatherSnoop's XML so Boisy's going to have to look into it.
Thu May 02, 2019 11:12 am
roquej offline
Anyone has any idea if the issue will ever be fixed? Right now, nothing works with Weathersnoop and Indigo
I ask because, in addtion to the comments in this thread, I have also left messages in the Weathersnoop support site and sent emails directly to support without a response.
It might be time to look at an alternative to Weathersnoop...
JP
Thu May 02, 2019 2:27 pm
Boisy knows about the issue and is looking into it AFAIK.
Thu May 02, 2019 2:49 pm
daveHawk offline
JP
I use WeatherCat and it's built-in webserver. I have an XML file that is updated every six seconds, using the GhostXML plugin to parse the output. It works flawlessly.
Thu May 02, 2019 6:45 pm
Korey offline
Likewise here with GhostXML!
I have it parse the output of my Meteobridge
Three cheers for @DaveL17 !! :D :D :D
Korey
Fri May 10, 2019 11:08 am
boisy offline
Hi everyone,
I apologize for not responding sooner. I've read the messages and am catching up from a busy month.
I finally had a chance to look at this. It appears that the "StandardError: LowLevelBadParameterError -- illegal character in XML tag name or value" is fixed in 3.0.1 which is available on the GitHub site (https://github.com/weathersnoop/weather ... digoplugin). I just installed Indigo 7.3 and it *appears* that it contains 3.0.0 of the WeatherSnoop plug-in which does show the XML error. So please download the 3.0.1 plug-in and let me know if it works.
Even in 3.0.1 there is the issue of errors showing up in the log when the plugin first starts. I'm looking into that now to see what might be the problem. But at least for me, 3.0.1 clears up the XML parsing error and my copy of Indigo is getting data from WeatherSnoop 4.
Fri May 10, 2019 11:59 am
roquej offline
boisy.
Thank you for looking into the problem. FYI - I have Indigo 7.3, Weathersnoop 4.0, and the 3.01 plugin. However, the error messages occur more than just at startup: They don't stop as long as the plugin is enabled.
May 10, 2019 at 1:54:20 PM
v3.0.1 of plugin WeatherSnoop is already installed but is disabled (enabling)
Loading plugin "WeatherSnoop 3.0.1"
Starting plugin "WeatherSnoop 3.0.1" (pid 15786)
Started plugin "WeatherSnoop 3.0.1"
May 10, 2019 at 1:54:53 PM
May 10, 2019 at 1:55:23 PM
May 10, 2019 at 1:55:57 PM
Fri May 10, 2019 2:17 pm
GRWilde offline
Still does not work at all. Constant errors as follows:
Starting plugin "WeatherSnoop 3.0.1" (pid 31703)
Error device "WeatherSnoop" state key outdoorTemperature_F not defined
Error device "WeatherSnoop" state key barometricTrend not defined (ignoring update request)
Error device "WeatherSnoop" state key soilTemperature2_F not defined (ignoring update request)
Error device "WeatherSnoop" state key soilTemperature2_C not defined (ignoring update request)
Error device "WeatherSnoop" state key soilTemperature1_F not defined (ignoring update request)
Error device "WeatherSnoop" state key soilTemperature1_C not defined (ignoring update request)
Error device "WeatherSnoop" state key leafTemperature1_F not defined (ignoring update request)
Error device "WeatherSnoop" state key leafTemperature1_C not defined (ignoring update request)
Error device "WeatherSnoop" state key soilTemperature4_F not defined (ignoring update request)
Error device "WeatherSnoop" state key soilTemperature4_C not defined (ignoring update request)
Error device "WeatherSnoop" state key siteName not defined (ignoring update request)
Error device "WeatherSnoop" state key siteLongitude not defined (ignoring update request)
Error device "WeatherSnoop" state key dayRain_in not defined (ignoring update request)
Error device "WeatherSnoop" state key dayRain_ft not defined (ignoring update request)
Error device "WeatherSnoop" state key dayRain_mm not defined (ignoring update request)
Error device "WeatherSnoop" state key dayRain_cm not defined (ignoring update request)
Error device "WeatherSnoop" state key dayRain_km not defined (ignoring update request)
Error device "WeatherSnoop" state key leafWetness3 not defined (ignoring update request)
Error device "WeatherSnoop" state key soilTemperature3_F not defined (ignoring update request)
Error device "WeatherSnoop" state key soilTemperature3_C not defined (ignoring update request)
Error device "WeatherSnoop" state key outdoorHumidity not defined (ignoring update request)
Error device "WeatherSnoop" state key indoorHeatIndex_F not defined (ignoring update request)
Error device "WeatherSnoop" state key indoorHeatIndex_C not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture1_inHg not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture1_cb not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture1_mb not defined (ignoring update request)
Error device "WeatherSnoop" state key monthEvapotranspiration_in not defined (ignoring update request)
Error device "WeatherSnoop" state key monthEvapotranspiration_ft not defined (ignoring update request)
Error device "WeatherSnoop" state key monthEvapotranspiration_mm not defined (ignoring update request)
Error device "WeatherSnoop" state key monthEvapotranspiration_cm not defined (ignoring update request)
Error device "WeatherSnoop" state key monthEvapotranspiration_km not defined (ignoring update request)
Error device "WeatherSnoop" state key leafWetness2 not defined (ignoring update request)
Error device "WeatherSnoop" state key leafWetness1 not defined (ignoring update request)
Error device "WeatherSnoop" state key siteElevation not defined (ignoring update request)
Error device "WeatherSnoop" state key leafWetness4 not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture3_inHg not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture3_cb not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture3_mb not defined (ignoring update request)
Error device "WeatherSnoop" state key dayEvapotranspiration_in not defined (ignoring update request)
Error device "WeatherSnoop" state key dayEvapotranspiration_ft not defined (ignoring update request)
Error device "WeatherSnoop" state key dayEvapotranspiration_mm not defined (ignoring update request)
Error device "WeatherSnoop" state key dayEvapotranspiration_cm not defined (ignoring update request)
Error device "WeatherSnoop" state key dayEvapotranspiration_km not defined (ignoring update request)
Error device "WeatherSnoop" state key siteLocation not defined (ignoring update request)
Error device "WeatherSnoop" state key rainRate_in not defined (ignoring update request)
Error device "WeatherSnoop" state key rainRate_ft not defined (ignoring update request)
Error device "WeatherSnoop" state key rainRate_mm not defined (ignoring update request)
Error device "WeatherSnoop" state key rainRate_cm not defined (ignoring update request)
Error device "WeatherSnoop" state key rainRate_km not defined (ignoring update request)
Error device "WeatherSnoop" state key windSpeed_mph not defined (ignoring update request)
Error device "WeatherSnoop" state key windSpeed_kph not defined (ignoring update request)
Error device "WeatherSnoop" state key windSpeed_mps not defined (ignoring update request)
Error device "WeatherSnoop" state key windSpeed_kn not defined (ignoring update request)
Error device "WeatherSnoop" state key siteSunsetTime not defined (ignoring update request)
Error device "WeatherSnoop" state key forecast not defined (ignoring update request)
Error device "WeatherSnoop" state key indoorTemperature_F not defined (ignoring update request)
Error device "WeatherSnoop" state key indoorTemperature_C not defined (ignoring update request)
Error device "WeatherSnoop" state key leafTemperature4_F not defined (ignoring update request)
Error device "WeatherSnoop" state key leafTemperature4_C not defined (ignoring update request)
Error device "WeatherSnoop" state key twoMinuteAverageWindSpeed_mph not defined (ignoring update request)
Error device "WeatherSnoop" state key twoMinuteAverageWindSpeed_kph not defined (ignoring update request)
Error device "WeatherSnoop" state key twoMinuteAverageWindSpeed_mps not defined (ignoring update request)
Error device "WeatherSnoop" state key twoMinuteAverageWindSpeed_kn not defined (ignoring update request)
Error device "WeatherSnoop" state key indoorDewPoint_F not defined (ignoring update request)
Error device "WeatherSnoop" state key indoorDewPoint_C not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture4_inHg not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture4_cb not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture4_mb not defined (ignoring update request)
Error device "WeatherSnoop" state key consoleBatteryVoltage not defined (ignoring update request)
Error device "WeatherSnoop" state key yearRain_in not defined (ignoring update request)
Error device "WeatherSnoop" state key yearRain_ft not defined (ignoring update request)
Error device "WeatherSnoop" state key yearRain_mm not defined (ignoring update request)
Error device "WeatherSnoop" state key yearRain_cm not defined (ignoring update request)
Error device "WeatherSnoop" state key yearRain_km not defined (ignoring update request)
Error device "WeatherSnoop" state key barometricPressureRelative_inHg not defined (ignoring update request)
Error device "WeatherSnoop" state key barometricPressureRelative_cb not defined (ignoring update request)
Error device "WeatherSnoop" state key barometricPressureRelative_mb not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteWindGust_mph not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteWindGust_kph not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteWindGust_mps not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteWindGust_kn not defined (ignoring update request)
Error device "WeatherSnoop" state key solarRadiation not defined (ignoring update request)
Error device "WeatherSnoop" state key transmitterBatteryStatus not defined (ignoring update request)
Error device "WeatherSnoop" state key outdoorHeatIndex_F not defined (ignoring update request)
Error device "WeatherSnoop" state key outdoorHeatIndex_C not defined (ignoring update request)
Error device "WeatherSnoop" state key extraHumidity5 not defined (ignoring update request)
Error device "WeatherSnoop" state key extraHumidity4 not defined (ignoring update request)
Error device "WeatherSnoop" state key extraHumidity7 not defined (ignoring update request)
Error device "WeatherSnoop" state key extraHumidity6 not defined (ignoring update request)
Error device "WeatherSnoop" state key extraHumidity1 not defined (ignoring update request)
Error device "WeatherSnoop" state key barometricPressureAbsolute_inHg not defined (ignoring update request)
Error device "WeatherSnoop" state key barometricPressureAbsolute_cb not defined (ignoring update request)
Error device "WeatherSnoop" state key barometricPressureAbsolute_mb not defined (ignoring update request)
Error device "WeatherSnoop" state key extraHumidity2 not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteAverageWindSpeed_mph not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteAverageWindSpeed_kph not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteAverageWindSpeed_mps not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteAverageWindSpeed_kn not defined (ignoring update request)
Error device "WeatherSnoop" state key uvIndex not defined (ignoring update request)
Error device "WeatherSnoop" state key extraHumidity3 not defined (ignoring update request)
Error device "WeatherSnoop" state key equilibriumMoistureContentOfWood not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture2_inHg not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture2_cb not defined (ignoring update request)
Error device "WeatherSnoop" state key soilMoisture2_mb not defined (ignoring update request)
Error device "WeatherSnoop" state key tenMinuteWindGustDirection not defined (ignoring update request)
Error device "WeatherSnoop" state key windDirection not defined (ignoring update request)
Error device "WeatherSnoop" state key thswIndex_F not defined (ignoring update request)
Error device "WeatherSnoop" state key thswIndex_C not defined (ignoring update request)
Error device "WeatherSnoop" state key windChill_F not defined (ignoring update request)
Error device "WeatherSnoop" state key windChill_C not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature5_F not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature5_C not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature4_F not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature4_C not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature7_F not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature7_C not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature6_F not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature6_C not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature1_F not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature1_C not defined (ignoring update request)
Error device "WeatherSnoop" state key outdoorDewPoint_F not defined (ignoring update request)
Error device "WeatherSnoop" state key outdoorDewPoint_C not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature3_F not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature3_C not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature2_F not defined (ignoring update request)
Error device "WeatherSnoop" state key extraTemperature2_C not defined (ignoring update request)
Error device "WeatherSnoop" state key outdoorTemperature_F not defined (ignoring update request)
Error device "WeatherSnoop" state key outdoorTemperature_C not defined (ignoring update request)
Error device "WeatherSnoop" state key indoorHumidity not defined (ignoring update request)
Error device "WeatherSnoop" state key siteSunriseTime not defined (ignoring update request)
Error device "WeatherSnoop" state key siteLatitude not defined (ignoring update request)
Error device "WeatherSnoop" state key leafTemperature3_F not defined (ignoring update request)
Error device "WeatherSnoop" state key leafTemperature3_C not defined (ignoring update request)
Error device "WeatherSnoop" state key yearEvapotranspiration_in not defined (ignoring update request)
Error device "WeatherSnoop" state key yearEvapotranspiration_ft not defined (ignoring update request)
Error device "WeatherSnoop" state key yearEvapotranspiration_mm not defined (ignoring update request)
Error device "WeatherSnoop" state key yearEvapotranspiration_cm not defined (ignoring update request)
Error device "WeatherSnoop" state key yearEvapotranspiration_km not defined (ignoring update request)
Error device "WeatherSnoop" state key leafTemperature2_F not defined (ignoring update request)
Error device "WeatherSnoop" state key leafTemperature2_C not defined (ignoring update request)
Error device "WeatherSnoop" state key monthRain_in not defined (ignoring update request)
Error device "WeatherSnoop" state key monthRain_ft not defined (ignoring update request)
Error device "WeatherSnoop" state key monthRain_mm not defined (ignoring update request)
Error device "WeatherSnoop" state key monthRain_cm not defined (ignoring update request)
Error device "WeatherSnoop" state key monthRain_km not defined (ignoring update request)
George Wilde
Fri May 10, 2019 2:32 pm
boisy offline
Hi everyone,
My observations were incorrect. There was definitely an issue with 4.1.8 introducing an illegal XML character, caused by some code refactoring that I performed. That is now fixed and 4.1.9 build 194 is up. This one does appear to fix the issue interfacing with the Indigo plug-in.
Please try this new build.
Fri May 10, 2019 4:08 pm
ticotice offline
Boisy,
Installed WS4.1.9 and reloaded the Indigo plug-in. Works great! I've added a few more WS instances to check all the WS states for the UI. It all appears to work well! No errors and correct data being displayed din Indigo. Thanks !
