Multiple attempts to create new devices
Sun Apr 14, 2019 3:38 am
Eagleye offline
Guys,
Have just started the setting up of my home automation system with Indigo and I have noticed that most of the time it takes multiple attempts to sync a new device to the system. I find that I need to continuosly press the sync button for the device to be added, which can sometimes take more than 15mins.
Does anyone know why this happens, and is there a way to speed up the process?
Sun Apr 14, 2019 5:14 am
FlyingDiver online
Re: Multiple attempts to create new devices
What kind of devices are you trying to set up?
Sun Apr 14, 2019 5:37 am
siclark offline
I notice you are using since zwave locks. Were they the problem or other battery devices? They can sometimes need several attempts to sync but mains devices should do it first time, depending where in location to the zwave stick they are and how much of your zwave network you've moved over from Vera.
And on that topic, there are plenty of us ex Vera users here, although I'm trying hard to blank that painful period of my life out!!
I paid up after less than a week of the trial. Once you get used to indigo actions and triggers it's so much faster to administer things in indigo Vs Vera.
Welcome.
Mon Apr 15, 2019 7:26 am
Eagleye offline
Thanks for your reply, All my devices are connected to mains power and they vary from brand names Fibaro, GOAP, Aeotec, remotec & Fakro, and devices include: Dimmer controller, single/double switches, roller shutters, window winders, multi sensors, RGBW controllers, Yale locks, contact relays, window sensors, sirens, AC controllers, RFXtrx transceivers, rain & wind sensors. It does not make any difference, it takes quite a number of attempts to sync any of these device.
I'm not sure if it is the network traffic that is causing this issue, I currently have nearly 100 active devices constantly communication
None of the new devices have been moved over from Vera, so I do not see this is causing any issue.
I have managed to sync all of my locks successfully. But I continue to have issues with other devices, such as:
> Multisensor 6 by Aeotec - They all seem very slow to respond and I'm not sure what the optimum setting for this device is.
> Fibaro RGBW devices, which I don't seem to be able to sync correctly and get them to work.
> Fakro window winders, where I'm experiencing issues in getting parameter changes to save, again it sometime takes multiple attempts and in some instances I can 't change them at all.
I could go on, but will stop here.
Any help would be greatly appreciated.
Mon Apr 15, 2019 10:56 am
Are you seeing any errors in the Event Log window? That's often the first place to look for trouble. We're all assuming you're talking (mostly) Z-Wave devices (not Insteon).
RFXtrx devices (433MHz)? That would be a completely different topic (since it's a different RF frequency than Z-Wave), though if the RFX can't talk to the RF devices it's supposed to talk to that might indicate that you have some kind of serious RF interference (though if your Vera network is still working that seems to indicate that it's not an interference issue).
