anode wrote:Can applescript change the ON/OFF values of the analog inputs?
set secondBinaryInput to item 2 of (get binary inputs of device "EZIO8T")
set firstAnalogInput to item 1 of (get analog inputs of device "EZIO8T")
support wrote:You can read the input values out as either binary or analog. Here is a binary example:
And here is an analog (integer) example:
- Code: Select all
Regards,
Matt
tell app "IndigoServer"
end tell
using terms from application "IndigoServer"
set firstAnalogInput to item 1 of (get analog inputs of device "LyncIO")
set (value of variable "LyncTEMP1") to firstAnalogInput
set firstAnalogInput to item 2 of (get analog inputs of device "LyncIO")
set (value of variable "LyncTEMP2") to firstAnalogInput
end tell
end using terms from
get device "LightSensor"
end tell
