Sonos 10.1 Update & Sonos Plugin v1.0.12
Sun Apr 07, 2019 1:23 pm
nlagaros offline
Re: Sonos 10.1 Update & Sonos Plugin v1.0.12
What is your reference IP set as in the plugin configuration?
chobo wrote:
Got it. Sent via PM. Thanks.
Sun Apr 07, 2019 1:30 pm
chobo offline
Good catch, Nick. Went from fixed to "auto" back to fixed while testing to see if that might resolve it... Just PM'd logs with a correct IP.
Sun Apr 07, 2019 1:48 pm
nlagaros offline
I found a problem with loading Favorites - affecting you and Terry. It will take me a bit to work through, but at least I see where the problem is.
Sun Apr 07, 2019 1:52 pm
chobo offline
Interesting. Anything we can do to “fix” our favorites and save you the hassle?
Sun Apr 07, 2019 1:55 pm
nlagaros offline
Unfortunately not. My parsing script is no longer valid. It seems Sonos has made a change and is nesting items within Favorites. I am going to rewrite that function.
Sun Apr 07, 2019 2:59 pm
Londonmark offline
One other issue I have is an enormous number of sonos playlists being created by the plugin all called Indigo_RINCON followed by a long string. They take ages to delete as the sonos app only lets you delete one at a time.
Sun Apr 07, 2019 3:59 pm
nlagaros offline
Last release for today and probably the next week or so. Sonos v1.0.15 is in the Plugin Store. I have refactored loading of Sonos Favorites.
Sun Apr 07, 2019 4:39 pm
chobo offline
Pretty certain v1.0.15 has done the trick for me. Will watch for errors over the next few hours/days and report back here if something changes. Thanks as always, Nick — this is one of a few plugins that are central to my significant Indigo install!
Sun Apr 07, 2019 6:14 pm
roussell offline
1.0.15 seems to be working well here too.
I didn't realize how dependent my family was on this plugin until the functionality was gone. Nick, thanks so much for jumping all over this so fast; this plugin and how you help out is one of the reasons Indigo is so great.
I put a little extra something in your PayPal to thank you for your hard work!
Thanks again!!
Terry
Sun Apr 07, 2019 6:34 pm
chobo offline
Great idea, Terry! I just found the PayPal link on the Plugin Store page and did the same. The least I/we can do for such a great and important addition to Indigo. Thanks again, Nick!!
Thanks again!!
Terry
Mon Apr 08, 2019 10:43 am
roussell offline
Thought I’d report back and say that everything still appears to be working fine.
I’m getting all of my announcements, and most importantly my daughter’s Sonos is correctly maxing out at 20% volume so she can’t crank it up and wake us up in the morning!
Thanks again Nick!
Terry
Mon Apr 08, 2019 10:54 am
rapamatic offline
I hadn’t thought of that use case. Great idea! I’ll have to add some volume limitation to my setup too.
Mon Apr 08, 2019 3:22 pm
nlagaros offline
Thank you!
Thanks again!!
Terry
Mon Apr 08, 2019 3:23 pm
nlagaros offline
Thank you!
Thanks again!!
Terry
Wed Apr 10, 2019 7:10 am
mundmc offline
Incoming donation from here as well, many thanks! I forget about donation options. Unfortunately Paypal won’t let me make FlyingDiver my prime beneficiary for my retirement plan.
