roussell wrote:Nick,
Just tried 1.0.13 and get the following errors:
Terry
- Code: Select all
Apr 7, 2019, 11:08:15 AM
Upgrading plugin Sonos to newer version 1.0.13 (previous version moved to trash)
Loading plugin "Sonos 1.0.13"
Starting plugin "Sonos 1.0.13" (pid 13554)
Started plugin "Sonos 1.0.13"
Sonos Your plugin version, v1.0.13, is current.
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 278, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2283, in closedPrefsConfigUi
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2681, in getSonosFavorites
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2571, in restoreString
AttributeError: 'NoneType' object has no attribute 'replace'
Sonos Adding ZonePlayer: 10.0.1.69, RINCON_949F3E0DFAF201400, Sonos - Garage
Sonos Adding ZonePlayer: 10.0.1.62, RINCON_000E587BD98601400, Sonos - Kitchen
Sonos Adding ZonePlayer: 10.0.1.64, RINCON_000E5829E14401400, Sonos - Living Room
Sonos Adding ZonePlayer: 10.0.1.67, RINCON_5CAAFD21E88E01400, Sonos - Madison's Bedroom
Sonos Adding ZonePlayer: 10.0.1.63, RINCON_000E58C47FC401400, Sonos - Master Bathroom
Sonos Adding ZonePlayer: 10.0.1.66, RINCON_5CAAFD21EA7601400, Sonos - Master Bedroom
Sonos Adding ZonePlayer: 10.0.1.65, RINCON_000E58DEE0B001400, Sonos - Pool
Sonos Adding ZonePlayer: 10.0.1.61, RINCON_000E58FE066601400, Sonos - Upstairs Den
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 47, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 371, in runConcurrentThread
TypeError: int() argument must be a string or a number, not 'NoneType'
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Domotics Pad Mobile Client Process command: updateMobileDeviceStates
Domotics Pad Mobile Client ErrorReceived status update for unknown device with Pairing ID: ugX7WLArD9oZVDxl6l0y
GreenSky MQTT Bridge Boat_Temp set to 85.9
