http rest command help with username
Mon Mar 11, 2019 1:16 pm
mpovolo offline
If I turn off Indigo server authentication, my http command for an action runs. Once I enable authentication, it won't work. I am not sure how to write an http command with username and password. I also have the option in this program I am using to enter json parameters.
Right not it looks like this for running the "test" action
http://192.168....:8160//actions/test?_method=execute
any ideas?
thanks
Mon Mar 11, 2019 2:54 pm
Re: http rest command help with username
The REST API uses HTTP digest authentication, so whatever is sending the request needs to know how to send HTTP Digest Authenticated requests.
Tue Mar 12, 2019 7:03 am
RogueProeliator offline
What application are you trying to execute this from? Perhaps someone else will use it and know or we can offer some suggestions.
Adam
Tue Mar 12, 2019 7:40 pm
mpovolo offline
an IOT widget on a Garmin watch. I keep getting invalid credentials but the same http command in a browser works fine
Wed Mar 13, 2019 8:13 am
It works in a browser because the browser has cached the digest authentication credentials so you don't have to enter it every time. The Garmin widget most likely doesn't support HTTP Digest Authentication if it doesn't collect a username/password.
There are workarounds though: I'd recommend reading this forum topic as it likely presents one option for you.
