juntta wrote:ConnectedDrive data contains similar data as other brands online services: door/hood lock status, location, car charge (EVs, PHEVs), fuel amount, mileage, service information etc. Its also possible to start cooling/heating remotely, lock/unlock doors, flash lights, set charging times (EVs, PHEVs).
I have slightly different approach with BMW ConnectedDrive and integrating Indigo: direct connection to ConnectedDrive with python scripts and use HomeKit devices to control car. I have modified python scripts found from web which can pull car(s) data from ConnectedDrive servers and execute some services (etc. pre cool/heat) with car. Then use variables & virtual devices published to HomeKit with HomeKit Bridge. For example, I get pushover notification if I have arrived home and haven't plugged car in or locked the doors. Unfortunately car cannot plug itself to charger but Indigo can lock it or I can do it manually with HomeKit.
I'm planning to turn these into plugin but lack of time and not-so-great coding skills have been postponing this for a while...
Turribeach wrote:Hi, I’m interest in this too. I have downloaded the script and it looks pretty easy to make into a plugin. I will give it a go as my first plugin as I have looking for something like this to jump into. I will let you know.
juntta wrote:Turribeach wrote:Hi, I’m interest in this too. I have downloaded the script and it looks pretty easy to make into a plugin. I will give it a go as my first plugin as I have looking for something like this to jump into. I will let you know.
If you want, I can send my versions of those scripts which already contain basic integration to Indigo but not in form of plugin.
Just PM your email to me and I’ll share
Turribeach wrote:I already have the script from jupe76 working in the command line. I need to look at what juntta sent me and create the plugin but it should be easy. I just haven’t been able to get time for this.
