Cynical Denon - Denon and Marantz AV Receiver control
Fri Mar 01, 2019 7:19 pm
kennybroh offline
Re: Cynical Denon - Denon and Marantz AV Receiver control
Just got an AVR-S740H and so far the plugin works like a charm for the few basic functions I've tested. On-off and mute. I really need to understand how to use the plugin formula to raise and lower volume by increments. I'll try to plow through the docs and tutorials, but any help would be appreciated.
Was very pleased that it just worked without any fiddling! Thanks.
Fri Mar 01, 2019 7:29 pm
Here are two that I use regularly:
Screen Shot 2019-03-01 at 7.26.17 PM.png (70.21 KiB) Viewed 5562 times
Screen Shot 2019-03-01 at 7.26.38 PM.png (55.44 KiB) Viewed 5562 times
There are also corresponding methods for volume down, as well.
Fri Mar 01, 2019 7:41 pm
kennybroh offline
Thanks. After I wrote that I tried =current+step as suggested in the docs. Since it was a small increment, I put 2 of them in the action. And I did the reverse for volume down. Is device.volume a built-in property? Is there a list of those somewhere?
Fri Mar 01, 2019 7:53 pm
kennybroh offline
So that worked, but 10 is a pretty big increment. Thanks for the tip.
Where can I find other built-in properties?
Fri Mar 01, 2019 8:06 pm
I was able to find an API protocol document for my receiver online. It contains all the commands like "CVC UP".
Yeah, 10 is a pretty big increment. But in my case, I use it "in reverse". When I'm watching live TV and the commercials come on, I hit the -10 button to moderate the volume, then (obviously) +10 when the program comes back on.
The center channel formula is for when the surround channels are turned up too high.
Fri Mar 01, 2019 8:09 pm
P.S. I can share the Denon document I use (AVR-E400) if you'd like to use it as a test bed source. I can't guarantee that it will work with other model numbers.
Fri Mar 01, 2019 8:28 pm
kennybroh offline
Sure, that would be helpful. Also my unit has an input called "Media Player" which isn't listed in the available input choices, I typed it in in all caps but it didn't work. The docs talk about an input map, but that can be found nowhere in the interface. Any idea how I might identify it?
Fri Mar 01, 2019 8:46 pm
kennybroh offline
thanks for the document. I just found the one for this model on Denon's site. And I saw that Media Player is MPLAY....
Getting there!
Fri Mar 01, 2019 8:49 pm
I just sent you a link to the file in a PM.
Here's a copy of the modified source map I use for my receiver.
AUX1=Aux Input,BD=Blu-Ray,CD,DVD,FAVORITES=Favorites,FLICKR=Flickr,GAME=Game,IPOD=iPod,IRADIO=Internet Radio,MPLAY=Media Player,NET=Network,PANDORA=Pandora,SAT/CBL=Satellite/Cable,SERVER=Server,SIRIUSXM=Sirius XM,SPOTIFY=Spotify,TUNER=Tuner,TV=TV Audio
(sorry, posted this reply to the wrong thread. I have too many simultaneous conversations going on! :D )
Fri Mar 01, 2019 8:51 pm
kennybroh offline
Yeah, MPLAY is what my doc said, but it doesn't work.... :cry:
Fri Mar 01, 2019 8:58 pm
kennybroh offline
Mar 1, 2019, 9:52:07 PM
   Cynical Denon Error             in set_source: Traceback (most recent call last):
  File ".../Server Plugin/cyin/debugging.py", line 58, in diagnostic_log
    yield
  File ".../Server Plugin/cyin/debugging.py", line 68, in diagnose_call
    return method(*args, **kwargs)
  File "plugin.py", line 96, in set_source
    self.zone.source = action.value
  File ".../Server Plugin/cyin/attr.py", line 237, in __get__
    value = dict.get(self.name + target if target.startswith("_") else target)
TypeError: descriptor 'get' requires a 'dict' object but received a 'str'
I tried putting it in single or double quotes but stilll get the same error....
Fri Mar 01, 2019 9:02 pm
kennybroh offline
Another odd thing. The mute toggle was working fine before, but now it stopped responding...
Fri Mar 01, 2019 9:04 pm
If you're talking about the source map, I don't have any quotes in there.
Screen Shot 2019-03-01 at 9.03.03 PM.png (75.04 KiB) Viewed 5537 times
Fri Mar 01, 2019 9:05 pm
kennybroh offline
OH, Duh... the source map is in the plug-in configuration. Now I get it!
Fri Mar 01, 2019 9:06 pm
Great! Good luck.
