Github Wiki Documentation Problem
Mon Feb 04, 2019 12:12 pm
autolog offline
Not sure this is the correct forum, but here goes. :D
I am trying and failing miserably to push my TRV documentation to the Github wiki, I am using the Github Desktop (1.6.1).
I can clone the wiki OK. I then update the wiki on my Mac and but when I try to do a push origin back to Github, I am getting the error:
Authentication failed. You may not have permission to access the repository or the repository may have been archived. Open preferences and verify that you're signed in with an account that has permission to access this repository.
If I am logged into my Github account using Safari, I can edit the Wiki and the main code base OK.
I have spent too long on this and am close to giving up :cry: - I thought this was meant to be easy! :shock:
I have tried googling without much success. There is obviously something I am doing wrong. :)
Mon Feb 04, 2019 12:34 pm
Re: Github Wiki Documentation Problem
You did set up your GitHub account info in the Preferences of GitHub Desktop, right?
I'm not sure if I've ever tried to push Wiki pages back to GitHub. I always edit those in a browser.
I just tested cloning one of my Wikis using GitHub Desktop. I edited one of the pages, made the commit, then pushed it back up. No issues.
Mon Feb 04, 2019 12:48 pm
autolog offline
Yes, and entered my 2FA code to get signed in.
AFAIK this is the only way you can imbed images in your pages as there isn't a mechanism to add them via a browser.
That's encouraging, thanks for testing. :)
Did you click the copy button under the Clone this wiki locally label on the wiki page. Then, go to the Github Desktop > File > Clone Repository and enter the previous details?
That seems to work OK for me but doing the push back doesn't :(
Mon Feb 04, 2019 1:12 pm
I don't recall doing that, but I must have. GitHub.com says I have authenticator app enabled.
You can, sort of. You need to have them on a website somewhere and then put in the link. I think for the few I have I created a different repository just for the images and then linked to it. I think I learned that trick from C4W.
The copy button copies the URL to the clipboard, then I used the URL tab of the Clone Repository dialog box. Just paste into the first text field.
Tue Feb 05, 2019 6:24 am
autolog offline
@FlyingDiver - Thanks for checking this out for me. :)
I am not sure why when I replicate what you do it doesn't work but it appears there is a bug in the Desktop that prevents wikis from being pushed back to Github. As yours worked and mine didn't, I don't know what triggers it. :?
Anyway, I have now managed to upload the documentation to Github. :D
I deleted my SSH key and recreated it following the instructions on Github Help.
The Desktop still wouldn't work but it does work if I use the command line:
git push origin master
No doubt this will be sorted at some point but it seems a bit basic when there are quite a few users complaining that it doesn't work.
Tue Feb 05, 2019 4:53 pm
It worked for me at some point, though I no longer own the repo where I was doing the pushing.
Tue Feb 05, 2019 5:02 pm
Ok, i just did this:
1) Copied the url from the Clone this wiki locally field on a wiki
2) Switched to Github Desktop and selected File->Clone Repository...
3) In the resulting dialog, I selected the URL tab and pasted the URL in to the first field and selected a location for the local path
4) Clicked Clone
5) Made a change
6) The change showed up in the Changes tab
7) Entered a summary and description and clicked Commit to master
8) Did a Push origin
And it worked as expected.
Tue Feb 05, 2019 5:42 pm
4) Clicked Clone
5) Made a change
Exactly what I did. You just documented it better. I'm retired, I get to be lazy....
Tue Feb 05, 2019 5:50 pm
:lol:
