Any real time temp sensors - non zwave?
Mon Feb 04, 2019 11:11 am
charliticus offline
I'm trying to add temperature and humidity systems to my system without using any z wave products. I'm interested in finding an IP based temperature and humidity sensors but can't find anything that makes a lot of sense. I've considered using inexpensive thermostats that simply don't control any HVAC, but just report temp and humidity. Thanks for your help!
Mon Feb 04, 2019 11:34 am
Re: Any real time temp sensors - non zwave?
Oregon Scientific does sensors that use RF, but not Z-wave. You'll need a compatible RF receiver, either an RFPlayer or an RFXCom.
For hardwired sensors, the 1-wire devices seem to be very popular, but I've never used one. I think they use an rPi hub.
What do you have against Z-wave?
Mon Feb 04, 2019 11:52 am
RogueProeliator offline
Check out the OWServer plugin/forum as there are multiple options - both wired and wireless... though they aren't super inexpensive. Dave can maybe chime in with more info.
https://forums.indigodomo.com/viewforum.php?f=150
Mon Feb 04, 2019 11:53 am
You can also do 1 wire with EDS and the OWServer plugin. That’s my preferred method. They have Ethernet and WiFi options available.
Jinx! Buy me a Coke.
Mon Feb 04, 2019 12:38 pm
charliticus offline
Nothing against Z-Wave really, I want something that will update more frequently, not be battery powered, and some of my sensors are out of range for where I need them. Thanks for the ideas!
Mon Feb 04, 2019 1:24 pm
lalisingh offline
Check out the PoE powered multisensor from Kentix. Attached is the output from these sensors.
Theses are not inexpensive.
Full Disclosure - I use them for my business - developing and installing building management systems.
[url]www.VillageWorker.com[/url]
Mon Feb 04, 2019 1:55 pm
Sevilsivle offline
That Sir, is an understatement!
Mon Feb 04, 2019 4:04 pm
charliticus offline
I ordered one of those Aeotec devices to check out that would solve one of my sensor location issues. Thanks for the suggestions!
