Wake on Lan
Sun Jan 20, 2019 7:15 pm
ginganinja offline
Wake on Lan
Hi All,
Was struggling with performing WakeOnLan functionality from within Indigo and found something I think is worth sharing.
It starts with the following piece of software, that is my favorite price, free!!!
http://www.readpixel.com/wakeonlan/
Download and install this on your Mac, now use their client software to test and troubleshoot your wake on lan functionality.
Once you get it working, you can then use Apple Script to call this app from within an Indigo Action Group.
Sample script:
tell application "WakeOnLan"
wakeup "192.168.4.135"
end tell
The other nice thing about this software is that I did a network sniff and basically the approach is to try about 6-7 different types of WakeOnLan signals (wonderful thing about standards is that there is so many to choose from). So your chance of getting it working is quite good.
Let me know if you have any questions/concerns, would be glad to help out.
Tue Jan 22, 2019 7:05 am
Re: Wake on Lan
Interesting. I don't have a need for this, but thanks for sharing.
Tue Jan 22, 2019 11:08 am
Re: Wake on Lan
here a python version. No need to install anything
You can put this into an action script and replace MAC number with your device number and the IP number to your BroadCast # likely ends with .255 (192.168.0.255 etc)
import socket
def sendWakewOnLan(MAC,ipN):
   data = ''.join(['FF' * 6, MAC.replace(':', '') * 16])
   sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
   sock.setsockopt(socket.SOL_SOCKET, socket.SO_BROADCAST, 1)
   sock.sendto(data.decode("hex"), (ipN, 9))
ipBC= "192.168.1.255"
mac = "12:34:56:78:AB:CD"
sendWakewOnLan(mac, ipBC)
Wed Jan 23, 2019 8:16 am
ginganinja offline
Re: Wake on Lan
Thanks Karl!
Agreed, I would rather call it straight from an action group. I'll give this a try and let you know how it works out.
RS
Sat Jan 26, 2019 6:17 am
Re: Wake on Lan
Ps. Fingscan as well as UniFi plugins have ping and wol as options to manage up/ downs of ip devices build in.
Mon Jan 28, 2019 10:47 pm
ginganinja offline
Re: Wake on Lan
Karl,
I test out your script and it worked great.
Thanks for the tip.
I will look into the other plugin's as well, but the script is pretty easy/fast.
RS
Mon Jan 28, 2019 11:04 pm
ginganinja offline
Re: Wake on Lan
Turns out that i already had winremote plugin installed and totally missed that it has wakeonlan, am using that now.
Fri Sep 01, 2023 8:40 pm
whmoorejr offline
Re: Wake on Lan
kw123 wrote:
here a python version. ....
import socket
Did something change? None of my old WOL scripts run anymore. Now I just get an error.
   Action Group                    Wake On LAN - 2nd Attempt
   Script Error                    action group "Wake On LAN - 2nd Attempt" embedded script error:
   Script Error                    'str' object has no attribute 'decode'
   Script Error                    Exception Traceback (most recent call shown last):
     embedded script, line 11, at top level
     embedded script, line 7, in sendWakewOnLan
AttributeError: 'str' object has no attribute 'decode'
Bill
My Plugin: My People
Sat Sep 02, 2023 12:22 am
Re: Wake on Lan
It’s python3
Will post a py3 version this weekend
Tue Sep 05, 2023 11:26 am
Re: Wake on Lan
Sorry I am out of town. Will have to wait until Tuesday next week.
Just became grandfather
Tue Sep 05, 2023 11:32 am
Re: Wake on Lan
Congratulations Grandpa!
Tue Sep 12, 2023 2:17 am
Re: Wake on Lan
This should work with py3
import socket
import struct
   mac = MAC.replace(":","")
   sendData = bytes.fromhex("FF" * 6 + mac * 16)  #  <---- changed from py2
   sock.sendto(sendData, (ipN, 9))
mac = "12:34:56:78:AB:AB"
Tue Sep 12, 2023 8:17 am
whmoorejr offline
Re: Wake on Lan
Worked like a charm. More importantly, how's that grandbaby?
Bill
Wed Sep 13, 2023 4:00 am
Re: Wake on Lan
Mom and baby are doing fine. As they live in Chicago and we in Vienna it will take some time before we see them.
