IFTTT Action plugin
Sun Jan 06, 2019 4:35 pm
Re: IFTTT Action plugin
jtburgess wrote:
But it seems there is only an IFTTT "action", I cannot use it as a "Trigger".
Will IFTTT triggers be implemented?
You can use the HTTPd plugin to trigger actions in Indigo based on an IFTTT event.
http://www.indigodomo.com/pluginstore/62/
Sat Jan 12, 2019 10:36 am
jltnol offline
So I saw this device in a write up about CES
https://lametric.com/en-US/time/overview
and noticed that it has some degree of IFTTT implementation. I know no one can promise me anything, but does it seem possible for Indigo to send data/info to IFTTT, and from there to this device?
I messed with IFTTT long before Indigo, but once I started with this software, I left it by the wayside for the most part. But it would be nice to be able to send data from Indigo and have it displayed on this device...
Anyone have any thoughts ?
Sat Jan 12, 2019 11:44 am
Sure looks like it's possible, but impossible to be sure without having a device to activate an account with. Without an account, I can't see what actions IFTTT can actually do with the device.
Amazon has it at a discount. I might pick one up to try. If it doesn't work, I can return it.
Though for the price, the Echo Show seems like a much better device. Or the Dot, which is a lot cheaper.
Sat Jan 12, 2019 12:32 pm
jltnol offline
I'll check the other options out.
Wed Jun 26, 2019 6:58 pm
hwitten offline
Trying to install.
Is the Indigo Maker Channel now webhooks? That's where the link in docs goes to. (https://ifttt.com/maker_webhooks).
The Webhooks API key is to be used?
Wed Jun 26, 2019 7:00 pm
hwitten wrote:
Trying to install.
Yeah, they renamed it.
The API key is used when making http calls TO IFTTT. Not web hooks called from IFTTT.
Wed Jun 26, 2019 7:04 pm
hwitten offline
Thanks. Currently just going 'to' IFTTT. Trying to control my AutoMower, to park it based on rainfall.
Wed Jun 26, 2019 7:42 pm
hwitten offline
Is there a way I can turn more debug on?
Action is logged in Indigo Event Log but not getting to IFTTT
I have a WebHook called Raining so as to avoid spaces issues.
I can trigger using curl from command line and also via a browser.
Wed Jun 26, 2019 8:00 pm
You could try a Python script instead of the plugin. This does the same thing the plugin does:
import requests
requests.get("https://maker.ifttt.com/trigger/<ACTION>/with/key/<API-KEY>")
Wed Jun 26, 2019 8:25 pm
hwitten offline
Thank you. Script works great.
Fri Aug 02, 2019 4:27 pm
Pacoramique offline
IFTTT Action plugin
Hello everyone,
This is my first IFTTT Action plugin install with Indigo. I create my IFTTT account and create my first applet.
The step by step i Indigo plugin store says at point 4 : "In the configuration window, you need to enter an API key for your IFTTT maker channel. To get one of these, you need to first connect to the Maker channel at https://ifttt.com/maker/ then the page should show "Your key is" and a key which you can copy and paste into the configuration window in Indigo."
BUT https://ifttt.com/maker/ return a 404 error page. I search in help and documentation but can't find my App API Key(s).
Any suggestion ?
regards
Fri Aug 02, 2019 4:29 pm
Go to https://ifttt.com/maker_webhooks and then click on "Documentation".
Wed Jun 03, 2020 5:49 pm
dkillmer offline
I just installed this plugin and added my API KEY. I created a trigger and added the action “Trigger Event (IFTTTAction Actions)” with my event name (no spaces). When I fire the trigger I can see it in the event log but there is no event log entry that anything happened with this action. Any suggestions?
Wed Jun 03, 2020 6:10 pm
What is your IFTTT action supposed to do?
You'll have to look at the IFTTT side of things. Unless your IFTTT action is supposed to trigger something in Indigo, I would not expect to see anything other than the trigger firing.
Wed Jun 03, 2020 7:19 pm
dkillmer offline
I see. I am using Webhooks to trigger a message from IFTTT. I confirmed the event name in IFTTT matches the event name in the Indigo trigger and I am not passing any values. The Webhook I created says it is active and it has never run. Thanks for your help!
Users browsing this forum: No registered users and 35 guests
