Sat Jan 05, 2019 11:42 pm
GlennNZ offline
kw123 wrote:
I have a fix, but hard to test .. I I could ask you?
on another note. just checked on my rpi3+ and ibeacon does not work anymore.. even with an external bye adapter.. no change for some time ..
there goes the weekend
Thanks Karl
Happy to test.
Glenn
Sun Jan 06, 2019 5:49 pm
Glenn: try v .263
Mon Jan 07, 2019 4:40 am
GlennNZ offline
Hi Karl,
Trying now, have lost connection to wlan1 rpi (sometimes happens)
But with other wifi ones now getting this:
pi@raspberrypi:~ $ cd /home/pi/pibeacon;sudo python master.py
Killed
pi@raspberrypi:~/pibeacon $ 20190107-21:35:33  master  IP find:::: wifiIP >>127.0.0.1<<; eth0IP: >><<;   hostnameIP >>['192.168.1.187']<<;   ipAddressRead >>192.168.1.187<<
20190107-21:35:37  master U.getIPNumberMaster bad IP number ...  ipHostname >>['192.168.1.187']<<  old from file ipAddressRead>>192.168.1.187<< not in sync with ifconfig output: wifi0IP>>127.0.0.1<<;   eth0IP>>
20190107-21:35:42  master  IP find:::: wifiIP >>127.0.0.1<<; eth0IP: >><<;   hostnameIP >>['192.168.1.187']<<;   ipAddressRead >>192.168.1.187<<
20190107-21:35:46  master U.getIPNumberMaster bad IP number ...  ipHostname >>['192.168.1.187']<<  old from file ipAddressRead>>192.168.1.187<< not in sync with ifconfig output: wifi0IP>>127.0.0.1<<;   eth0IP>>
20190107-21:35:51  master  IP find:::: wifiIP >>127.0.0.1<<; eth0IP: >><<;   hostnameIP >>['192.168.1.187']<<;   ipAddressRead >>192.168.1.187<<
20190107-21:35:56  master U.getIPNumberMaster bad IP number ...  ipHostname >>['192.168.1.187']<<  old from file ipAddressRead>>192.168.1.187<< not in sync with ifconfig output: wifi0IP>>127.0.0.1<<;   eth0IP>>
x20190107-21:36:01  master  IP find:::: wifiIP >>127.0.0.1<<; eth0IP: >><<;   hostnameIP >>['192.168.1.187']<<;   ipAddressRead >>192.168.1.187<<
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:15:0f:3a  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 29  bytes 4548 (4.4 KiB)
        TX packets 29  bytes 4548 (4.4 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.187  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::ba27:ebff:fe40:5a6f  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:40:5a:6f  txqueuelen 1000  (Ethernet)
        RX packets 905  bytes 105966 (103.4 KiB)
        TX packets 211  bytes 29950 (29.2 KiB)
Another one:
        ether b8:27:eb:e9:a7:c5  txqueuelen 1000  (Ethernet)
        RX packets 14  bytes 1920 (1.8 KiB)
        TX packets 14  bytes 1920 (1.8 KiB)
        inet 192.168.1.189  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::ba27:ebff:febc:f290  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:bc:f2:90  txqueuelen 1000  (Ethernet)
        RX packets 346  bytes 41036 (40.0 KiB)
        TX packets 206  bytes 27352 (26.7 KiB)
pi@raspberrypi:~/pibeacon $ 20190107-21:41:25  master  IP find:::: wifiIP >>127.0.0.1<<; eth0IP: >><<;   hostnameIP >>['192.168.1.189']<<;   ipAddressRead >>192.168.1.189<<
20190107-21:41:38  master U.getIPNumberMaster bad IP number ...  ipHostname >>['192.168.1.189']<<  old from file ipAddressRead>>192.168.1.189<< not in sync with ifconfig output: wifi0IP>>127.0.0.1<<;   eth0IP>>
20190107-21:41:43  master  IP find:::: wifiIP >>127.0.0.1<<; eth0IP: >><<;   hostnameIP >>['192.168.1.189']<<;   ipAddressRead >>192.168.1.189<<
Mon Jan 07, 2019 12:26 pm
should be fixed in .264
         if ifConfigSections[ii].find("wlan0  ") > -1 or ifConfigSections[ii].find("wlan0:") > -1 or \
            ifConfigSections[ii].find("wlan1  ") > -1 or ifConfigSections[ii].find("wlan1:") > -1:
> -1 was missing in line one when I added the "or"
Mon Jan 07, 2019 11:28 pm
GlennNZ offline
Running now .. one typo found I think.. will update if anything else.
 piBeacon Error                  error in socket-send to rPi:192.168.1.184  [{"cmdLine": "setTime=2019-01-08 16:24:57.665683", "command": "general"}]
   piBeacon Error                  in Line '6542' has error='global name 'sself' is not defined'
   piBeacon Error                  {u'192.168.1.184': {u'count': 0, u'pi': u'4', u'time': 1546924953.854585}}
   piBeacon Error                  error in socket-send to rPi:192.168.1.184  [{"cmdLine": "setTime=2019-01-08 16:24:57.666818", "command": "general"}]
   piBeacon Error                  {u'192.168.1.184': {u'count': 1, u'pi': u'4', u'time': -1546925097.666811}}
seems largely cosmetic and otherwise all good - rpi wlan1 up and going, connecting fine.
Glenn
Tue Jan 08, 2019 1:17 am
fixed in v .266. -- sorry fo the many typos
GN
Tue Jan 08, 2019 1:56 am
GlennNZ offline
kw123 wrote:
fixed in v .266.
Upgraded and all good!
Sun Jan 20, 2019 11:49 am
johnfdl offline
So I have a couple fitbits (Charge 2) and while my phone ble scanner can see them, they do not show up in the PiBecon (though my XY finders are seen just fine). I'd like to do away with the XYs and use just the fitbit, but unsure if anyone has been sucessful in using the Fitbit. I have un-ignored all beacons so there are none being ignored, but only the RPis and the XY beacons show as active. I've tried reloading the plug-in.
Has anyone successfully been using their Fitbit?
Is there something obvious I should check?
Sun Jan 20, 2019 3:56 pm
The system only sees iBeacon and equivalent messages.
It does not send anything.. just listening.
It sees the flower pot
And setting up my Mac mini as ble devices
It sees that too, but not reliable. As sometimes when the mac goes to sleep it shuts down Ble
Sun Jan 20, 2019 4:01 pm
johnfdl offline
ok.....so it sounds as if it does not see (i.e., receive beacon signal from) my fitbit. The XY's are quite reliable, but after replacing batteries so many times, the slot where you pry them open is becoming worn out....so I figured if fitbits work, then I don't have to look into buying a new set of XYs.
Sun Jan 20, 2019 4:56 pm
I am now using the iHere rechargeable . !!!WAP!!! form factor
believe charge hold s> 4 weeks, see my previous post :
https://forums.indigodomo.com/viewtopic.php?f=187&t=15360&start=75
Sun Jan 20, 2019 8:49 pm
mundmc offline
Exactly my experience with the XY’s.
Mon Jan 21, 2019 7:51 am
johnfdl offline
Thanks. I ordered a couple of these. Question, what does WAP stand for? Wireless Access Protocol? Wife Acceptance Pfactor?
Mon Jan 21, 2019 10:07 am
W approved
Sun Jan 27, 2019 1:38 pm
johnfdl offline
So I bought a couple Nonda Aiko beacons. But when I charge them up, they dont show up as devices on my Indigo piBeacon folder. So I thought I need to update perhaps to the latest plugin. I did that and my Event log shows:
   Starting plugin "piBeacon 7.100.269" (pid 36020)
   Started plugin "piBeacon 7.100.269"
   piBeacon                        initializing    ...
   piBeacon                        path To files:      =================
   piBeacon                        indigo              /Library/Application Support/Perceptive Automation/
   piBeacon                        installFolder       /Library/Application Support/Perceptive Automation/Indigo 7/
   piBeacon                        plugin.py           /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon-2.indigoPlugin/Contents/Server Plugin/
   piBeacon                        Plugin params       /Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.karlwachs.piBeacon/
   piBeacon                        PluginLogFile       /Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.karlwachs.piBeacon/plugin.log
   piBeacon                        Plugin short Name   piBeacon
   piBeacon                        my PID              36020
   piBeacon Critical Error         --------------------------------------------------------------------------------------------------------------
   piBeacon Critical Error         The pluginName is not correct, please reinstall or rename
   piBeacon Critical Error         It should be   /Libray/....../Plugins/piBeacon.indigoPlugin
   piBeacon Critical Error         It is: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon-2.indigoPlugin
   piBeacon Critical Error         please check your download folder, delete old *.indigoPlugin files or this will happen again during next update
   piBeacon Critical Error         ---------------------------------------------------------------------------------------------------------------
  File "plugin.py", line 8619, in runConcurrentThread
  File "plugin.py", line 8639, in dorunConcurrentThread
  File "plugin.py", line 8424, in initConcurrentThread
AttributeError: 'Plugin' object has no attribute 'indigoInputPORT'
   piBeacon Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   piBeacon Error                  in Line '2493' has error='[Errno 2] No such file or directory: u'/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.karlwachs.piBeacon/dataVersion''
   piBeacon Error                  Error in plugin execution runConcurrentThread:
I have reloaded the plugin and now piBeacon does not work. No beacons deteected:
Log shows this:
an 27, 2019 at 2:54:51 PM
   v7.100.269 of plugin piBeacon is already installed but is disabled (enabling)
   Loading plugin "piBeacon 7.100.269"
   Starting plugin "piBeacon 7.100.269" (pid 40388)
   piBeacon                        plugin.py           /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/
   piBeacon                        my PID              40388
   piBeacon                        myLogSet setting parameters -- logFileActive= standard; logFile= ;  debugLevel= []
   piBeacon                        testing if variable enableTimeTracking_piBeacon is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   piBeacon                         --V 7.100.269     initializing  --
   piBeacon                        starting UpdateRPIqueues
   piBeacon                         .. config read from files
   piBeacon                         ..   def startup(self): setting variables, debug ..   finished
   piBeacon                         ..   starting tcpip stack
   piBeacon                         ..   tcpip stack started
   piBeacon                         ..   checking sensors
   piBeacon                         ..   checking devices tables
   piBeacon                         ..   checking BLEconnect
   piBeacon                         ..   checking beacons
   piBeacon                         ..  initalized, starting loop
Jan 27, 2019 at 2:57:16 PM
   piBeacon                        return code from fix ("spawn sftp -o ConnectTimeout=15 pi@192.168.2.124\r\npi@192.168.2.124's password: \r\nPermission denied, please try again.\r\r\npi@192.168.2.124's password: \r\nPermission denied, please try again.\r\r\npi@192.168.2.124's password: \r\nAuthentication failed.\r\r\nConnection closed\r\r\n", 'expect: spawn id exp9 not open\n    while executing\n"expect "sftp" {  send  "quit\\r" }"\n    (file "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp" line 50)\r\n') trying again to configure PI
And Beacon status in Indigo shows IPconnection and BLE down
Page 67 of 78 1 ... 64, 65, 66, 67, 68, 69, 70 ... 78
Users browsing this forum: No registered users and 21 guests
