Limit Plugin Logging
Thu Jan 03, 2019 8:46 pm
I'm on a jag to improve logging within my plugins.
Now, regardless of the logging level set with:
self.indigo_log_handler.setLevel(debug_level)
all calls to self.logger.xxxxxx are written to the log file at 'com.plugin.indigoPlugin.whatever'. If I want to optimize logging to the plugin's log file -- that is, only write to the log file when it's actually needed -- the only way I've found to do that is conditional evaluation:
debug_level = int(self.pluginPrefs.get('debugLevel', '30'))
if debug_level <= 20:
    self.logger.debug('foo')
or
verbose_logging = self.pluginPrefs.get('verboseLogging', False)
if verbose_logging:
Under normal operation, there's plenty of stuff that doesn't need to be logged (like valuesDicts and whatnot) that I might want to invoke under certain conditions. I guess the best way to describe what I'm after is to have the plugin log handler work the same way as the Indigo Event log handler--in other words, it would be like taking the Indigo Event log and filtering for only my plugin's messages (then, I could use threaddebug to write messages that only the plugin log file would get.) Does that make sense?
Is there a better mousetrap?
Thu Jan 03, 2019 10:58 pm
Re: Limit Plugin Logging
I am trying to have 3 dimensions in logging
1. Severity : info, warning error critical.
2. area : eg comm, logic, update .. etc what every your plugin does
3. reports: nicely formatted data print outs. Created when requested by user
For info, warning, error, reports... I like to have different formats
Error, critical should get the full treatment
Timestamp, method, line number, message
Info... does not need the items
It looks as if the current logger only allows one format at a time for each log file.
Question. Could we get some examples from the gurus how to do some of these things like in the sdk for other functions
That would help me
Currently I am doing this “manually” in my own logger methods .. but I can not get the method included in the message automatically. Rest is ok
Would like to switch but I have >> 3000 lines of logging across my plugins ...changing everything manually is not an option.
Fri Jan 04, 2019 10:23 am
RogueProeliator offline
I think there are multiple ways of doing this, but I wouldn't put the conditional in there... I'm almost positive that the only things written to the "private" log that you reference are done because they meet the logging level threshold of threaddebug (Jay posted somewhere the value of it, I can't find it off hand). Instead of using those helper functions, you can use the generic .log() call for sending messages. It requires passing in the level as the first argument.
SO, if you have a variable that is already storing the logging level set by the user, just pass that in to the log function. If you want to log super-debug stuff only sometimes, set the variable to a value that won't be caught by the thread debug level. When the enhanced logging is turned on by the user, simply update that class/global/whatever variable and when the .log() gets called it will magically match and be logged.
At least, that is my understanding -- Jay or other Python experts can jump in if I got any of that wrong.
Adam
Fri Jan 04, 2019 11:46 am
yes the
logformat = logging.Formatter('%(asctime)s.%(msecs)03d\t%(levelname)-12s\t%(name)s.%(funcName)-25s %(msg)s', datefmt='%Y-%m-%d %H:%M:%S')
self.plugin_file_handler.setFormatter(logformat)
self.mylogger = logging.getLogger("Plugin")
self.mylogger.setLevel(logging.THREADDEBUG)
self.mylogger.log(50,"---text-50--")
self.mylogger.log(10,"---text-10--")
prints :
2019-01-04 11:41:13.044   CRITICAL       Plugin.startup                    -- text 50 --
2019-01-04 11:41:13.044   DEBUG          Plugin.startup                    -- text 10 --
to the private logfile
now I like to change the format for different logging levels, info and critical don't need the same detailed info ..
==> how to use >1 format for the same logger for different levels
or how do i define another logger that points to the same file?
ps
sys._getframe(1).f_code.co_name
returns the name of the calling function. -- one of my issues.
Fri Jan 04, 2019 12:38 pm
You're the second person to say that. Maybe I'm initiating the logging helper functions improperly.
With the following in __init__:
        # ========================= Initialize Logger =========================
        self.plugin_file_handler.setFormatter(logging.Formatter('%(asctime)s.%(msecs)03d\t%(levelname)-10s\t%(name)s.%(funcName)-28s %(msg)s', datefmt='%Y-%m-%d %H:%M:%S'))
        self.debug      = True
        self.debugLevel = int(self.pluginPrefs.get('showDebugLevel', '30'))  # plugin pref set to 30
        self.logger.debug('Foo')
I get this in the personal log file (I like that name):
2019-01-04 12:29:07.437   DEBUG        Plugin.__init__                     Foo
With this (leaves out self.debug):
        # self.debug      = True
        self.debugLevel = int(self.pluginPrefs.get('showDebugLevel', '30'))  # again, 30
I get this in the personal log file:
2019-01-04 12:31:54.246   DEBUG        Plugin.__init__                     Foo
And with a pause:
        # self.debug      = True
        self.sleep(5)
I get:
What am I not seeing?
Fri Jan 04, 2019 12:43 pm
Reread your note:
I think that might be my disconnect.
If everything that meets the level of threaddebug will be posted to the private log file -- regardless of the plugin debug level (options are 10-50) -- then that's consistent with what I'm seeing.
Fri Jan 04, 2019 1:07 pm
this seems to work = create 2. stream into the plugin logger file "Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/<<pluginid>>/plugin.log"
      logformatERROR = logging.Formatter('%(asctime)s.%(msecs)03d\t%(levelname)-12s\t%(name)s.%(funcName)-25s %(msg)s', datefmt='%Y-%m-%d %H:%M:%S')
      logformatINFO  = logging.Formatter('%(asctime)s    %(msg)s', datefmt='%Y-%m-%d %H:%M:%S')
      self.plugin_file_handler.setFormatter(logformatERROR)
      self.methodTracer = logging.getLogger("Plugin")
      self.methodTracer.setLevel(logging.THREADDEBUG)
      self.methodTracer.threaddebug(u"CLASS: Plugin")
      self.methodTracer.info(u"startup  .... ")
      self.methodTracer.log(50,u" -- text 50 -- ")
      self.methodTracer.log(10,u" -- text 10 -- ")
      self.myLogger = logging.getLogger()
      fh = logging.FileHandler(self.PluginLogFile, 'a')
      fh.setFormatter(logformatINFO)
      self.myLogger.addHandler(fh)
      self.myLogger.setLevel(logging.WARNING)
      self.myLogger.log(10," myLogger 10")
      self.myLogger.log(20," myLogger 20")
      self.myLogger.log(30," myLogger 30")
      self.myLogger.log(40," myLogger 40")
      self.myLogger.log(50," myLogger 50")
does:
2019-01-04 13:05:53.548   THREADDEBUG    Plugin.startup                   CLASS: Plugin
2019-01-04 13:05:53.548   INFO           Plugin.startup                   startup  ....
2019-01-04 13:05:53.548   CRITICAL       Plugin.startup                    -- text 50 --
2019-01-04 13:05:53.548   DEBUG          Plugin.startup                    -- text 10 --
2019-01-04 13:05:53     myLogger 30
2019-01-04 13:05:53     myLogger 40
2019-01-04 13:05:53     myLogger 50
independently of the indigo plugin logger, but puts the lines into the indigo plugin logfile
Fri Jan 04, 2019 1:31 pm
It looks like the following property is being set:
logging.THREADDEBUG = 5
So that is capturing all logging with a level above 5. All of your calls are using logger.debug() which is logging at a level of 10 I believe.
Try:
self.logger.log(4, u'Test... should not capture anywhere!')
self.logger.log(5, u'Captured only in private plugin log')
self.logger.log(10, u'Captured to indigo log if you set the logging level to 10, but not if set to INFO (20)')
Note that here you are setting the log handler of the Indigo Log, but not the one that goes to the private plugin log:
To set the level for the plugin-specific log (not sure why you would want to, but can...)
self.plugin_file_handler.setLevel(logging.DEBUG)
Does that make more sense?
Adam
Fri Jan 04, 2019 2:22 pm
Crystal. Thanks Adam!
I'm not in a position to test at the moment, but I *think* you've given me my answer.
def closedPrefsConfigUi(self, valuesDict, userCancelled):
    if self.pluginPrefs['verbose']:
        self.plugin_file_handler.setLevel(logging.THREADDEBUG)
    # will only be written to private log if self.pluginPrefs['verbose'] is set to True
    self.logger.threaddebug(u"pluginPrefs = {0}".format(dict(valuesDict)))
Fri Jan 04, 2019 2:30 pm
Here are some clarifications (which may or may not have been mentioned in the thread above:
  • self.debugLevel isn't implemented so has no effect on logging (all levels should be set either on the logger itself or the handler)
  • Levels cascade - so if you set self.logger to a higher level, nothing will get down to the handler. The handler is the more granular place to set levels.
  • self.indigo_log_handler is the handler that directs to the Event Log window and is set by default to INFO
  • setting self.debug is just a shortcut for setting the indigo_log_handler to DEBUG (I wouldn't use it or self.debugLog since those were just there to help convert from the old logging)
  • self.logger.debug, self.logger.warn, self.logger.info aren't Indigo shortcuts, they are implemented in the logger module itself so there's really no advantage to using the raw self.logger.log command with the level as the first parameter (IMO) .
  • logger.THREADDEBUG = 5 # this is the default level for self.logger and self.plugin_file_handler
  • I added self.logger.threaddebug as a shortcut synonymous to the ones built into the logger module if you're using the defined logger.THREADDEBUG level.
  • THREADDEBUG was added because I thought that it would be nice to have an even deeper debug option for multi-threaded plugins where you might not want to see detailed debugging from threads but debugging from other areas.
Any other questions I missed?
Fri Jan 04, 2019 5:18 pm
Thanks Jay. Nothing for me. You also cleared up a couple other things for me too, so thanks for that.
For the future, this seems to work well for my use case:
    def __init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs):
        self.debug_level = int(self.pluginPrefs.get('showDebugLevel', '30'))
        self.indigo_log_handler.setLevel(self.debug_level)
        self.plugin_file_handler.setLevel(10)
        if valuesDict['verbose']:
            self.plugin_file_handler.setLevel(5)
        return True
    self.logger.threaddebug(u"Foo")  # will only log to the private log file if valuesDict['verbose'] is True
Sun Jan 06, 2019 2:34 pm
FYI, using the constants (logging.DEBUG, logging.INFO, etc.) is more future proof since those constants are defined in the python logging module. And we'll make sure that logging.THREADDEBUG always works in the context of a plugin as well. And, at least to me, it's clearer to read than the raw numbers that they represent.
Tue Sep 10, 2019 3:11 am
berkinet offline
I have been working on getting my logging better organized and trying to get up to date with recent, and not so recent, changes in Indigo logging support. In the past, I have used this little snippet to allow me to easily add debugging type logging to a plugin:
func = inspect.stack()[0][3]
      self.logger.debug(u"%s: called for: %s, %s, %s." % (func, typeId, devId, valuesDict))
Which produces something like:
MyPlugin           somePluginMethod: myPluginDeviceType, 123456, ...
Looking at your post above, it seemed I could define a format string for messages sent to the server log but with only a subset of the elements you are using in a log file. Indeed:
self.indigo_log_handler.setFormatter(logging.Formatter('%(funcName)s: %(msg)s'))
does what I wanted. The only problem is, this formats all log messages in this manner and I just wanted to format debugging messages. At the moment I am unable to wrap my feeble brain around how to do that. Any brilliant suggestions would be most welcome.
Tue Sep 10, 2019 6:04 am
I'm not 100% sure I understand, but let's try. :D
As you found, you can set the logging format handler anytime you want. If it were me, I think I'd set the initial logging formatter in __init__ and then I'd wrap the rest of my logging in a method and call that as needed..
self.log_me(error_state=False, level=20, msg="something important")
Then you could select the proper logging formatter in the call to the method by setting error_state. Based on my very quick tests, this will adjust the output to the private debug log, but leave Indigo's Event Log unchanged.
Is that even close?
I do something similar when I pass log messages between threads or subprocesses and the main Plugin class. I throw everything in a dict, put the dict in the queue, and do the logging from the Plugin class.
Tue Sep 10, 2019 6:31 am
berkinet offline
DaveL17 wrote:
I'm not 100% sure I understand, but let's try. :D ...
Hmmm. Let me try again. As you note, I can set the format handler in __INIT__ to
Now, later on I have two log messages
self.logger.info(u"Something very normal happened to {}'.format(dev.name))
self.logger.debug(u"Here is the complete device {}".format(dev))
I would like the debug message to follow the format set in __INIT__ but I want the info message to be printed exactly as coded. I.e. no formatting. BTW, I am not, yet, interested in writing to the private log file, just Indigo's log.
