Scene Error
Fri Dec 21, 2018 5:42 am
Coolcaper offline
Scene Error
I am trying to execute the Christmas scene with the Garden Mini Poles which are similar to these:
https://consumer.sylvania.com/our-produ ... /index.jsp
I am getting this:
Action Group Front Garden Poles Xmas Scene
Sylvania Lightify Error Error in plugin execution ExecuteAction:
File "plugin.py", line 865, in startScene
IndexError: index 4 out of list range
Tried it with the Color bulbs as well and same result.
Fri Dec 21, 2018 9:34 am
rbdubz3 offline
Re: Scene Error
Coolcaper - guess I need to hire a QA team for my stuff.. Or figure out an easy way to clean all of my settings so I can test my plugin as a brand new install
I think I have found the issue - but may try to fix it a bit more cleanly.. Can you try the following interim hack:
    * Open the 'Edit Scenes' dialog and select 'Christmas'
    * switch Scene Type to 'Circadian'
    * add some values into the Circadian settings if they are empty
    * Click 'Save Scene' to save the settings
    * switch Scene Type back to 'Match Color/Temp' (existing color/temp settings from before should be retained)
I automate because I am lazy :D - My Plugins: https://forums.indigodomo.com/viewforum.php?f=309
Fri Dec 21, 2018 10:34 am
Coolcaper offline
Re: Scene Error
No dramas mate. Quite late here now. Will try it out later today and let you know. Thanks for trying to sort it out.
Fri Dec 21, 2018 9:11 pm
Coolcaper offline
Re: Scene Error
Thats seems to have fixed it! Thanks
Tue Jan 01, 2019 4:58 pm
rbdubz3 offline
Re: Scene Error
fixed this bug in the latest version 1.0.3
Wed Jan 02, 2019 3:52 am
Coolcaper offline
Re: Scene Error
Thanks for the update but it seems the bug is still present:
  File "plugin.py", line 769, in startScene
IndexError: index 0 out of list range
Also when I restart the plugin I get:
Starting plugin "Sylvania Lightify 1.0.3" (pid 13152)
   Started plugin "Sylvania Lightify 1.0.3"
   Sylvania Lightify               Startup - SylvaniaLightify Plugin, version=1.0.3
   Sylvania Lightify               Initializing Lightify Hub, IP Address=10.0.1.42
   LightifyDirect                  Initializing python lightifydirect, version=1.0.3
   LightifyDirect                  ...Lightify Connecting...
   Sylvania Lightify               pluginPrefs lacks scenesList.  Adding.
   Sylvania Lightify Error         Error in plugin execution startup:
  File "plugin.py", line 247, in startup
IndexError: string index out of range
   Sylvania Lightify               Starting device: Front Garden Poles, lightifyHubIpAddr=10.0.1.42
   Sylvania Lightify               Starting device: Porch Lights, lightifyHubIpAddr=10.0.1.42
   Sylvania Lightify               Starting device: Side Entrance Lights, lightifyHubIpAddr=10.0.1.42
   Sylvania Lightify               Starting device: Side Yard Lights, lightifyHubIpAddr=10.0.1.42
   Sylvania Lightify               Starting device: Verandah Lights, lightifyHubIpAddr=10.0.1.42
   Sylvania Lightify               Starting concurrent thread
Wed Jan 02, 2019 3:17 pm
rbdubz3 offline
Re: Scene Error
sorry 'bout that coolcaper .. try out version 1.0.5 ..
So in v1.0.3 I attempted to modify the persistence of scenes to support future updates more seamlessly. However, I missed on some corner cases in converting from old persistence to new. If I am still missing something that is causing issues, I will probably request that we clean out your preferences for the plugin and start fresh (you'll need to re-create any customizations to your scenes).. Apologies for the inconvenience
Thu Jan 03, 2019 4:43 am
Coolcaper offline
Re: Scene Error
Seems to be working fine. Will update if any issues. Thanks for your work on this.
