Error
Thu Dec 20, 2018 4:47 am
Coolcaper offline
Error
Thanks for the plugin, however after installing, I get the following error:
20 Dec 2018 at 18:40:28
Installing and enabling plugin Sylvania Lightify v1.0.1
Loading plugin "Sylvania Lightify 1.0.1"
Starting plugin "Sylvania Lightify 1.0.1" (pid 34879)
Sylvania Lightify ..lightifyHubIpAddr=127.0.0.1
LightifyDirect ...Logging lightifydirect
Sylvania Lightify Error Error in plugin execution InitializeMain:
File "<string>", line 1, in <module>
File "plugin.py", line 46, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/SylvaniaLightify.indigoPlugin/Contents/Server Plugin/lightifydirect.py", line 213, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/SylvaniaLightify.indigoPlugin/Contents/Server Plugin/lightifydirect.py", line 218, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/socket.py", line 228, in meth
error: (61, 'Connection refused')
Stopping plugin "Sylvania Lightify 1.0.1" (pid 34879)
Stopped plugin "Sylvania Lightify 1.0.1"
Re-enabling it produces the same result.
Thu Dec 20, 2018 5:21 am
CliveS offline
Re: Error
Sylvania Lightify ..lightifyHubIpAddr=127.0.0.1 <<<<<<<<< That does not look right, should be the IP of the Sylvania hub and no way to set it up
Edit,
You could replace the 127.0.0.1 in line 44 of the plugin.py to match your real ip of the hub.
CliveS
Thu Dec 20, 2018 8:25 am
rbdubz3 offline
Re: Error
The Plugin Configuration will allow you to set the Hub IP address.. See Install/Setup notes here - https://github.com/rbdubz3/sylvania-lig ... tall-setup
I automate because I am lazy :D - My Plugins: https://forums.indigodomo.com/viewforum.php?f=309
Thu Dec 20, 2018 8:29 am
rbdubz3 offline
Re: Error
In hindsight - loopback ip 127.0.0.1 is a bad default - I'll change this and also improve the improve the error messaging for initial connection to the hub
Thu Dec 20, 2018 9:40 am
rbdubz3 offline
Re: Error
CliveS - apologies for the bad startup there. Sometimes you focus on certain pieces of the code that you overlook some glaring stuff :(
Please use V1.0.2.. It has improvements to the startup initialization and error handling/messaging.. The new version will allow you to properly set the Lightify Hub IP address.
Fri Dec 21, 2018 2:13 am
Coolcaper offline
Re: Error
Working now. Thanks
