Trigger Doorbell Rings Siren 3
Updated "SmokeBridge 3 Main Attic" on
INSTEON Commands Error plugin does not define method setCurrentAlarmType
auto_man wrote:I tried to use the new commands for setting the Insteon Siren between the siren and chime sounds, but I get the following error:
Anyone experience this or have ideas about it?
INSTEON Commands Error plugin does not define method setCurrentAlarmType <<<<<<<<<<<<<<<< trying to get it to set chime vs siren on the fly
Schedule Doorbell Rings Siren 3 (delayed action)
Updated "SmokeBridge 3 Main Attic" off
Jan 19, 2020 at 10:17:30 AM
Sent INSTEON broadcast set button down
PowerLinc Linking - entered discovery linking mode (240 seconds)
PowerLinc Linking - sending engine version request to 3F.0B.AC
PowerLinc Unexpected command 02 0B (flushing)
PowerLinc Linking - received engine version 02 from 3F.0B.AC
PowerLinc Linking - sending id request for device information to 3F.0B.AC
PowerLinc Linking - received id request response from 3F.0B.AC
PowerLinc Linking - initializing remote device "Insteon Siren 3" (address 3F.0B.AC, firmware version 45)
PowerLinc Linking - initialize complete
PowerLinc Linking - syncing remote device "Insteon Siren 3" (address 3F.0B.AC, firmware version 45)
PowerLinc Linking - syncing of this device not possible remotely (skipping) <<<<<<<<<<<<<<<<<<<<<Don't understand this.
PowerLinc Linking - sync complete
PowerLinc Linking - syncing PowerLinc links (address 3C.4C.82)
PowerLinc Linking - . . adding: INSTEON plc link to controller 3F.0B.AC, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . adding: (not added -- probably already exists)
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - exited linking mode
Jan 19, 2020 at 10:18:40 AM
Received INSTEON "Thermostat Fam Room" temperature changed to 67.0
cd /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4
more Plugins/.INSTEON\ Commands.indigoPlugin/Contents/Info.plist
Last login: Tue Jan 21 22:59:43 on ttys000
Hamiltons-Mac-mini:~ hamiltonwilliams$ cd /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4
Hamiltons-Mac-mini:Indigo 7.4 hamiltonwilliams$ more Plugins/.INSTEON\ Commands.indigoPlugin/Contents/Info.plist
<plist version="1.0">
<dict>
<key>PluginVersion</key>
<string>2.2.2</string>
<key>ServerApiVersion</key>
<string>2.0</string>
<key>IwsApiVersion</key>
<string>1.0</string>
<string>INSTEON Commands</string>
<key>CFBundleIdentifier</key>
<string>com.perceptiveautomation.indigoplugin.InsteonCommands</string>
<key>CFBundleVersion</key>
<string>1.0.0</string>
<key>CFBundleURLTypes</key>
<array>
<dict>
<key>CFBundleURLName</key>
<string>http://wiki.indigodomo.com/doku.php?id=plugins:insteon_commands</string>
Plugins/.INSTEON\ Commands.indigoPlugin/Contents/Info.plist...skipping...
<dict>
<array>
<dict>
</dict>
:...skipping...
<dict>
<array>
<dict>
</dict>
</array>
:...skipping...
<dict>
<array>
<dict>
</dict>
</array>
</dict>
:...skipping...
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)...skipping...
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)...skipping...
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)...skipping...
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)
<dict>
<array>
<dict>
</dict>
</array>
</dict>
</plist>
(END)
Users browsing this forum: No registered users and 17 guests
