Is there anything special to do in getting Parrot codes working as a device to turn on and off. I can get the "Send Text" command working for the device "ON A1 PARROT" works.
When I try and add the device as a Parrot i get this error:
- Code: Select all
RFPlayer Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1179, in deviceUpdated
File "plugin.py", line 215, in deviceStartComm
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/RFPlayer.indigoPlugin/Contents/Server Plugin/protocols/x10.py", line 16, in __init__
KeyError: key deviceType not found in dict
